can you imagine using this for 9 hrs!!!!
"Just cleaned and serviced, this rugged commercial brick or block cutting machine will make light work of accurately cutting bricks or blocks to specific lengths or shapes. The 450mm diameter diamond wheel still has 5mm of diamond segments left – well over half its life available. It has completed a job cutting scores of thousands of bricks cleanly and accurately in half to build a pseudo Flemish single skin wall. It will cut blocks width wise or length wise up to 140mm thick (Typical 6” block). Length stop can be set with a toggle clamp for repetitive cutting of specific lengths – closers etc. Powered by a Petters AA1 3000rpm 3hp diesel engine which readily handle cranks into life. It will run all day on its large tank of red diesel fuel."
£450 ... local-ish to me if anyone's brave enough to want it ..... those lil' Petters are noisy lil' ba***ards :oops:
Jimoz
I had a load of aircrete blocks cut into brickette last year but was only 40 or 50 quid from memory for around 200. I won the blocks off a job and needed the brickettes. Wasn't messing with the sthilly for 50 quid
Ive got
Reo's Clipper's here still and am likely to have it some time :rolleyes: whilst he finds a new home to relocate to ...
it's a hell of a weapon for cutting stone with ... quick and clean -- apart from the mess it creates behind it .. :oops: ...
really needs locating in a dedicated spot, with a sheet or wall behind it to catch what gets ejected
great for making stone bricks with :giggle:
that's leccy and loud enough ... wouldn't want to be listening to an AC1 at 3,000 rpm all day, two feet from my ears
Won? What, like a raffle?
T whiting
T whiting
Ive got
Sounds like it's missing the rubber mat from the back of the frame the one on ours was missing and I replaced it with a bit of carpet and some bits of builders band it returns all the sludge to the tray there a good bit of kit and if you leave the tray to drain overnight they don't make that much mess.
I'll agree that there noisy though the blade on ours is louder than the Honda engine that runs it
