Backhoe
They are on the front of the backhoe..... ;)
Were on both ends of mine ;):giggle:
Got similar 3.7% on a new Timberwolf chipper through my usual finance guy at claas last month, Timberwolf’s subsidised offer through Arb lease was 1.5% more despite telling me I’d not get cheaper elsewhere!
Finally but the bullet on one after getting asked all the time if we had one, not been asked since 🙈
Sods law
Build height direct mount shouldn't be too far off the s lock that's on the 6t in that photo and and tbf we should compare a tilty on both 8t and 6t so all things being equal photo is a fair comparison.
ah -- now you're sneaking in direct mount .. big difference then ... direct it'll still be a lot taller than with just the hitch as is .. would guess at 2-2.5X ... thought you were just hoping for as much reach as your exiting 8t on the new 6t
that'll not be far off with a swivelly hinge attached ;)
Only for reaching out to grade though. If trying to reach to tip it won't be the same. I suppose you can do some twiddling and turn the bucket around as you reach. But it depends what you want it for.
I think it's easier just to accept certain things. You will never have enough reach and never have enough lift capacity.
Looks like 10cm in it
S lock says 28cm
39cm I think on R2 rototilt - 38cm on engcon ec206.
S lock says 28cm
looks about right
an additional 11cms for the hinge sounds optimistic :unsure: .. but 'spose they've measured it
note the extra 5 Deg.s between pins which all tilty manufacturers seem to factor in between upper and lower pins .... can't recall why ATM, but there is a reason and read it once .. Aiden might recall why?
top hitch'd double that up and end up with a stack at 67cms, mean
anyone else looking for a WN??
would the plate really be stuck on ??? :unsure:
in the 8t and below pages
forgot to post this last night:unsure::rolleyes:
