Moderattor🐾
For reference I charge £500 a shift.
Need to cover going with the lorry worst case
it was a pita arse for me getting my 8t moved for 10y, so I used to use the 3t a lot more to save organising transport, my 6t is the only machine I use nowadays thanks to the truck and engcon , I really wouldn't want to go back to a 3t machine at this point unless space dictated.When I cost my own time into it I realise I'm just not bothered. Much easier to offload the hassle. I only work locally though so two trips to move a digger and loader is less of an issue.
Yeah fair points. I had a dumper turn up the other day. Spotted a screw in the tyre when it was still on the lorry. That tyre was fine with screw removed but then another tyre went down went I was on the job and it looked like a screw had been in there- they charged me for the repair and I can't say it wasn't me but pretty sure it wasn't me!I hate hiring in plant, it never comes when it says, it hangs around on site for days after you have offered it, you always get the wrong spec machine.. they always try and charge diesel, I even had them try and charge me for a operators manual on the last hire!! I just cba with it! Absolute last resort to hire anything in, I’d rather shovel!!!
Easily avoidable with a tyre string kit and a battery compressor. Worth keeping in the truck just for the truck and your own wheeled plant to be fair.Yeah fair points. I had a dumper turn up the other day. Spotted a screw in the tyre when it was still on the lorry. That tyre was fine with screw removed but then another tyre went down went I was on the job and it looked like a screw had been in there- they charged me for the repair and I can't say it wasn't me but pretty sure it wasn't me!
On that. Recommend a decent string kit? Looking other day seems a plethora of similar looking ones online.Easily avoidable with a tyre string kit and a battery compressor. Worth keeping in the truck just for the truck and your own wheeled plant to be fair.
I’ll have a look what brand mine is, must be 20yrs old now and still good!On that. Recommend a decent string kit? Looking other day seems a plethora of similar looking ones online.
I've got all that onboard anyway- this one was right through the tread lug- don't think I would have got a string in there- or at least didnt want to risk botching it given hire machine. I just pumped it up every hr to get the job doneEasily avoidable with a tyre string kit and a battery compressor. Worth keeping in the truck just for the truck and your own wheeled plant to be fair.
OKO baby!I've got all that onboard anyway- this one was right through the tread lug- don't think I would have got a string in there- or at least didnt want to risk botching it given hire machine. I just pumped it up every hr to get the job done
Unless it's an inner tube.Easily avoidable with a tyre string kit and a battery compressor. Worth keeping in the truck just for the truck and your own wheeled plant to be fair.
They are all much the same and they will all get you out of s**t.On that. Recommend a decent string kit? Looking other day seems a plethora of similar looking ones online.
Use a 5mm drill in the cordless to ream the hole,a friend told meOKO baby!
Works ok but the proper 6mm carbide burr with a point on it is readily available.Use a 5mm drill in the cordless to ream the hole,a friend told me
dittoI have a handheld variant of that, useful to clean the hole out first, also have the glue(probably gone off now ) which helps shove the needle into the thicker tyres if anything!
I shall have one of them in the box ,as usual you use what is to handWorks ok but the proper 6mm carbide burr with a point on it is readily available.
Tyre Repair Carbide Mill Cutter 6mm | CDB06 | Sealey
Ø6mm Burr made from high quality Carbide steel. For use when performing tyre repair, to create a clean hole before plugging punctures.www.sealey.co.uk
I bought this 1 in DecemberOn that. Recommend a decent string kit? Looking other day seems a plethora of similar looking ones online.
