Russell
What's the best tracked dumper with high tip? The messersi and Kubota looks a bit small capacity and the hiowa has that annoying lift mechanism sticking out the top. Are the JCB reliable?
Most JCB little dumpers end up in auctions on pallets.
This^^^^^ I owned one. It was cheap to buy new and did my work but turning was especially crap. The Slanetrack ones are very good and have a larger capacity skip than most. But in the 500kg bracket, I'd say you cant beat the Cormidi. Good track frame design, nice and narrow and fast. The petrol ones do drink fuel though but its a small compromise to pay as they are simple to fix.Always driveshaft/sprocket issues and motor issues too.... such a shame as there a cracking little design.... just ran out of steam when it came to the undercarriage
Is there a common engine fault with the JCB htd5? Only asking as most I have seen on pallets at auction have the engine in bits in the skip
It's on the latest htd5 that got an hour meter.Maybe if the oil was changed as it should be (probably every 100 hours on an engine that small) they wouldn't be so bad? You know how most hire companies are with maintenance.
