Wacker plates
I was wondering what a wacker on the tb016 would work like, anyone tried that?
You need more flow. Mine is a good tool on the E27, but barely works on the E19 and you'd struggle to lift it with an 016!
That was the 1 I was looking at no clue if any good quality wise
Yup, that’s the model I have.
Hg2702
Hg2702
Trouble is with limited reach on a mini digger you’ll soon be tracking on what you’ve wacked
According to the spec it is 240 kgs which seems a lot for a plate less than 18’’ wide.
It's bloody brilliant if you want serious compaction in awkward places. But too heavy and needs too much flow for anything less than a 2.5t.
I've used mine for filling in things like swimming pools prior to paving and rip/relevel/comapct repairs on footpaths up hills. It's no roller replacement but a handy tool to have in the arsenal.
Finally got myself one, good as new, top top end money but I like to try and buy the best of what’s available! ,I couldn’t bring myself to part with 4K for a new one! View attachment 34724
Looks mint, where did you get that from?
I'm back at looking for a reversible. Got the 80kg engine going turned out it runs ok with less fluid in the sump 🤣.....
Agitator has now crapped itself though, at least one seal has gone plus what ever else has got damaged inside. Was running and then when switched off decided to just spit a load of red hot oil out of the side of it 🙄
shouldn't be too much of a job to replace the bearings with sealed for life,s and bung some seals in too, for good measure :giggle:;)(y)
‘‘Twas a plant dealer on eBay, sells loads of nice gear! Had a saved search for years and one finally came up! Then today another 2018 came up from another seller 😂
From the pdf manual I’ve got…
