I have no idea what this means. My Kingpost swings or pivots btw, it doesn't track parallel like some do (I think) if you see what I mean.
If you turn your kingpost slightly then use the main slew it has the effect of moving the boom in a parallel fashion to what your trying to dig. So if you are digging a long straight trench each time you track back you adjust the kingpost to make sure you follow a straight line.
Can also be used to help you get the boom square to a bucket when changing buckets. To change the angle of attack when digging out a rock or root. To allow you to work closer to the machine in tight circumstances. And when scraping up so the bucket pulls the pile into a tighter pile rather than spreading it out. Basically before moving the tracks think if you can achieve the same effect by moving the kingpost
