Wednesday and Vicki's bloody boiler'd locked out yet again
.... this was going to be the 5th one of these in three months
and my last one from stock so shot into town, 'fore going to her place for some more
usual issue ... water saturated and not allowing kero through ... has only been an issue since the last kero delivery
... boiler runs a tiger loop supply so flows a lot of kero ... if it was gravity fed, I doubt there'd be an issue as it'd settle out, but being constantly circulated/agitated, it never does
got three perfectly clean and now dried out filters sat, but the little square section seals in the canister top are always half a mil bigger, after a week or two, in kero, so'll never go back in the seat... therefore it gets the works each time .. couple of quid a throw, so no biggy.
However .. this last filter'd only been in there a week - max. and the tank is down to about a third, so the mix is a lot more concentrated and i am pretty PO-ed ....
decided to leave said 025 out and stick the cannister back together empty ... seal actually stayed put, so give it a try .....
tank is less than a year old - new poly and the fuel's clean as a whistle .... fired it up and ran sweet and clean .... and is continuing to do so, so far ....
gonna run the tank down low - not going to be needed much longer, hopefully, then i'll drain it down, clean it out and examine what comes out after it's been stood a while to settle
long term a water separator's on the cards, 'cos this is pissing me off, big time and might raise said tank, so's i can do away with the tiger loop feed and go to gravity - only talking a couple of feet max.
yesterday Pam decided she wanted to mow the lawn, this time ... said to her the Countax is 'whispering' to me ATM and is gonna break down at some point .. if it stops do not sit there cranking it .. I'm waiting for it to stop, so i can out find why?
sure enough, she'd just finished and it coughed and died, middle of the lawn, grass box full .....
's a heavy little sod when Charlie Hodna's not behaving and I wasn't gonna go playing with the fuel system in the middle of the lawn and kill the bloody grass .... the damned moles're doing a good enough job on that front ..... as that's what the symptoms had now manifested as .... let it sit for a few minutes and managed to get it to run on chokey enough to get it to me bench and tools ....
bowl, float and needle out, tiny bit of tish in the needle jet ... all cleand and running like a good un again
.... so while it's there thought it prudent to give it one of its several cleans, that it gets through the season .....
was in need
..... back together and doused in a good spray down of light oil, stuck it back on ..... mower was looking decidedly 'used', so gave some spray a try, that me BIL had dropped in for me - swears by it for getting stuff clean ....
have to say ... I am convinced .... looked awesome with a wipe over
apart from the flakey bits ... it's not a miracle concoction
so she's all ready for the next round in the war against the grass
phone call 10.15 this morning, from the people we visited a fortnight or so ago, after my last trip to Caeeerdiff ...... "we'll be with you in about an hour" .." fine, what're you driving?" .. "18tonne rigid box "
was expecting him to say a 7.5
so had to shift a few things about to make some space to spin him round, when he got here ... anyway, mission accomplished and two nice lads they were too .... spun 'em round and backed 'em down to the patio for an off load .....
saved a lot of lugging about.
couple of hours later and pam has an ear to ear grin ... it had arrived and was out the box .......
few more bits to assemble .... and HTF this had ended up like this is anyone's guess .. mine is it'd been dropped whilst being wrapped ...
'sposed to be flat and being ali, I wanted a few pix, fore i tried straightening it, in case!! ..... it did and was fine ... could well have not
and snapped ... so got the table together and even bigger grin from Pam ....
and I'm not allowed to sit on it in me working gear (which was clean on yesterday after getting kero-ed Wed.s)..... not gonna spend much time on it then
I succumbed to an addition to it all Monday - my choice - it gets 'kin hot sat there, when the sun's actually out, so added a new brolley to the order ... had seen 'em down there, but wasn't overly impressed at the fact it was 8ft off the deck .. until I'd you-tubed 'em and sussed their detail ... and could see why ..... will come to that later, but it arrived too, all 8ft of it
now all i have to do is create it a base as i was damned if I was coughing up nigh on 250 quid for a 90kg lump of granite to bolt it to ...... I have just the thing ..... 120kgs of 24" x 2" thick flywheel .. will look just fine with a nice coat of paint and suitably fettled to fit the purpose ..... after I get the current leg off it and create a new base attachment for yon bracket
job for tomorrow .....
had some help today, to get it out from where it was lurking, with lil' Jake ..... and then giving it a clean off
Clara on her 'hop up' .... bench is just the right height for both of us then ... she's game for most things ..... as long as they don't take tooooooooo looooooong
.... didn't extend to disc-ing the leg off
have to say I am well impressed with the quality of the brolley's attachment point (and the brolley) ....... some over kill with the base weight isn't going to hurt - up here
was in need
