Help please Fuse popping
Deanofire
Instead of wasting loads of fuses wire a bulb across the fuse terminals. Bulb will light whilst there is a short to earth and go out when you disconnect the source of the short. Disconnect anything passing through that fuse one at a time to eliminate. If nothing extinguishes the light it’s time for a wiggle test on all areas of wiring harness you can get to. Possible wire shorted to earth.
thanks thats a good idea will give that a go
Deanofire
Good idea thanks for that
Rob65
I haven’t looked at the wiring diagrams so don’t know if this is logical but it’s a quick and easy check.
Have you tried disconnecting the alternator? When the regulators in alternators fail they can give a short circuit to ground.
very good shout Rob
Deanofire
Wool that be connected at position 1 on the key though?
That's true, but the main output terminal is always hot to the battery. The charge lamp on the dash is switched , but it's low current and won't blow fuses.
@Diggerdavey suggestion of a lamp is very good. If you choose the lamp carefully, you can use it to judge the current (you may need a 5W and a 50W lamps to cover a wide range of current)
Is now a good time to suggest re-settable fuses?
Deanofire
will give the alternator disconnect a try anyway , and i dont think they make the re settable fuses in 40A but thanks anyway
did consider this the other night ..... long term though is it worth the investment ,although not astronomic .. once sorted?:unsure:
Diggerdavey
The beauty of the test light method is you don’t have to keep resetting it. If it’s on there is a short. Wiggling wires (if it is a loom short) will allow the light to flicker if you move a loom that’s shorting. A resettable fuse has its place but I think in this instance a bulb would prove less frustrating during the testing process.
Deanofire
Am with the digger now. Have used a test lamp and when I turn ignition to pos 1 I hear the fuel pump running as it would but the bulb glows and dims so I cant really leave it connected . Any idea what else to disconnect?
try the pump for starters and see what happens with the lamp
Deanofire
Disconnected power and plug to alternator and still the same. Am really running out of ideas now
Sorry I dont understand. I am really out of my depth here. Sorry
run a pair of leads of suitable size from the existing fuse point to the new resettable and locate the new resettable some where convenient
Deanofire
Right. Tank lifter pump and small silver top fuel pumps disconnected but I have a clicking on and off like an indicator noise coming from the pump area of the engine when I connect the lamp again and it's still flashing
Deanofire
But I dont have a re stable fuse. Just the test lamp
