shopping tip: truck with crane
You need to be able to load her up 👌
What does yours tare are Mike?
Mine with a 30tm HMF, but a different design of plant body is 16t
We are around the 15.6T mark. But being a 6 legger grosses out at 28T. So in theory if you can get the axle weights right can take 12T payload
About the same, mine was 15.8t and I round up to 16 to allow for a couple of extra chains etc I carry since weighting :giggle:
Double check on the GTW, as 26t is the max here.
I`ve got a run up to nearly your neck of the woods in it tomorrow, to Kintore
I was under the impression 26T was max on 6 leggers but on my last run over the vosa lane the inspector pointed out we have a 9ton front axle 11.5 ton mid and 7.5ton tag which tally’s to 28T. This was discussed as what I thought was a percentage of a load wasn’t what I thought.
I got a run to Inverurie to be done this week myself. What you trapesing up to Kintore for? If you don’t mind me asking
30tm HMF, ???
but does it still exist? where he worked, never heard of, in my part, engineer bonfiglioli, fish cranes, effer, pm and others that I don't remember, marquises loader cranes for scrap .. I don't remember more ...
I've got the same, a 11.5, 7.5, and a 9, but it's still only 26t, as per the plating certificate, just gives you a bit of leeway for loading, I can't put the full payload over or just behind the rear axles.
I'm bring some shot blasting equipment up, a firm I do transport for specialists in making it, this is one of there self contained blast rooms.
30tm HMF, ???View attachment 32746View attachment 32747
HMF still exists, they are made in Denmark.
The top picture is a 14/15tm crane, the bottom one I can't make out the model, but it looks to be a Z fold type so could be used as a scrap/timber/clamshell loader but still fold up.
I'll need to double check but I'm sure our plate is 28T
I think a truck similar to this could be fine, even a 4-axle 3x 4wd would be fine, maybe you would use a low-wheeled trailer, the problem is finding the right crane, neither too small nor too big and powerful the weight and dimensions of it could be inadequate for use, performance and service to be provided to users, perhaps with the tipper body it could be used to provide small construction sites with supplies of sand gravel to supply small construction sites, perhaps to collect and transport residual rubble debris rubble , large earthmoving works I exclude it, the truck with the crane is heavy and awkward slow in its maneuvers, it already has to support the load of the crane so if the ground is wet it risks sinking, getting bogged down and being trapped in quicksand mistake ?
View attachment 32765View attachment 32767View attachment 32769
gonna be interesting see him get his arm in the air with those steel beams loaded as they are ????? :unsure:o_O:ROFLMAO::ROFLMAO:
I MACCARRUNI: PIATTO TIPICO DOMENICALE CALABRESE​
today and Sunday finally we eat well large table in the countryside, my aunt makes macaroni alla peasant the famous Calabrian macaroni al ferretto a delicacy, returning to the truck, the HMF crane, I don't know it, someone could give me some impression, what do you think? thank you.
I totally agree - there are a couple of firms specialising in tree removal with hiabs and I can’t help but think something will go wrong at some point…
All the grapple saw hiabs as far as I am aware are based out of Surrey as is a lot of this mechanical dismantling kit. Most densely wooded county in England.
They are impressive to watch but you must be bloody confident on your weight guestimates
Must admit hiabs roto handlers etc being used to take trees down are just an accident waiting to happen and when it does will we see then used for it again.
They have been in use for a long time in Germany. Apparently it is near impossible to use traditional tree surgery techniques over there
This☝️ how long until HSE decide it's too dangerous to send monkeys up trees anymore..
And from what Ive seen and Eddie's commentary it's a grey area that's going to get screwed I we at some point ...a big prang will hasten it I guess.🤷
