Wtd- single cab 4wd pickup
That's cool as, If I had the cash I would buy it. It must be a piece of piss to do a galv chassis on one of them.
My disco is nearly there, just tidy up the hoses, front bumper to go on and a bit of paint on the inner arches.
Do the pickups have 3 seats in the front?
I want to build something for off road so either a P38, a disco 1 or a defender hi cap.
Yeah either 3 seats or can have a cubby box instead. I've squeezed the wife and child into my hicap many a time!
Thats the problem with the Japs, it will give less trouble but they still break and cost twice as much for parts. Disco chassis was £3500 and a defender is £2000 odd
I think half the trouble with landrover is the saturated aftermarket parts available for them. Plenty of cheap Chinese shite fitted to defenders which invariably last 6 months or leak out the box. Jap more likely to buy genuine parts which are probably fat better quality
That's very cheap- think they have gone up alot recently like everything else. Mind you company near here is supplying and fitting galv chassis. Just under £4k for a 110. Seems very reasonable
I collected the chassis from a 4x4 show at Billing last summer, and had the deal on the bulkhead whilst there.
Did you say you had a low mileage V8 D1?
Want to sell it?
one of 200-ish hot wire injection 3.5s made .... with 40k on the clock...back seats never sat in when I had it and'd never had a tow bar fitted ('til it fell into my hands :) )
one geriatric owner with a disco sized garage in the centre of Caerrrdifff :giggle::giggle:
the way LRs are ATM it's going nowhere .. ;)
was running like a watch, 'til i got in it one morning and the brake pedal went to the floor .. :oops::(:censored:
that's the second bit that needs me to fix it ....
the first job is find out WTF the EFi ECU is, ... trace it's +ve supply to the fuse that is no longer providing said ECU with lectrickery .. and sort that so it'll run again ..... injectors aren't currently firing :cry:
if it were a classic RR, or an SD1, or a 3.9 D1, I'd know exactly where to look ...... (y)
but this is a Solihull special/bitza/development vehicle and it'll be tucked into whatever space they could find under the dash, whilst still allowing room for the not inconsiderable bulk of the air-con system and heat exchanger.:unsure::(
It is going to be a challenge to not only find the ECU, but also it's power source AND FUSE from where ever they hacked into the loom to pick it up from ..... and NO -- it's not in the main or aux fuse boxes 🤬🤬
Russell
Sounds like its a bit special for what I had in mind. I want to do some 4x4 trials and a bit of green Laning. I need to try and suppress the urge to get another dirt bike.
To be fair for what parts I've needed tidying my hilux up I've actually found parts quite reasonable. One of the things that can make jap stuff seem expensive is muppet part swappers who don't realise you can get the parts to repair some bits and do replace whole units. There's also where you source stuff.
Disco 1 are very good value for money if you can find one that's not too hanging!
Russell
doesn't the pre chassis snapping shape have the explodie engine?
Turns out it has a clutch issue and front prop removed due to "unbalanced" but seems cheap if someone can be arsed to mess with, worst case got to be worth more as spares
