Did you say you had a low mileage V8 D1?
Want to sell it?
one of 200-ish hot wire injection 3.5s made .... with 40k on the clock...back seats never sat in when I had it and'd never had a tow bar fitted ('til it fell into my hands
one geriatric owner with a disco sized garage in the centre of Caerrrdifff
the way LRs are ATM it's going nowhere ..
was running like a watch, 'til i got in it one morning and the brake pedal went to the floor ..
that's the second bit that needs me to fix it ....
the first job is find out WTF the EFi ECU is, ... trace it's +ve supply to the fuse that is no longer providing said ECU with lectrickery .. and sort that so it'll run again ..... injectors aren't currently firing
if it were a classic RR, or an SD1, or a 3.9 D1, I'd know exactly where to look ......
but this is a Solihull special/bitza/development vehicle and it'll be tucked into whatever space they could find under the dash, whilst still allowing room for the not inconsiderable bulk of the air-con system and heat exchanger.
It is going to be a challenge to not only find the ECU, but also it's power source AND FUSE from where ever they hacked into the loom to pick it up from ..... and NO -- it's not in the main or aux fuse boxes
