Brake master cylinder
P
Popeye
That doesn’t look like the original master cylinder?
Where have you been told that Dot 4 is correct? Not saying that it’s definitely not, but you need to check that Dot 4 is suitable for the axles.
Is it worth flushing it out ? It’s been in 2 days !!
was my exact same thoughts (y)
The cap on the reservoir might say DOT4, but that doesn't help if it's not original.
Wet brakes should never get hot enough to need a DOT fluid, but it still may be correct.
Just to clarify, the pedal is very soft, but the fluid level isn't dropping?
When you bled the lines, did you also slacken off the connecting line? It looks like it could trap some air in it,
P
Popeye
Yeah I bled the cylinder too ! I pushed the pedal down and nipped the connecting lines 👍👍
Quick question ! If it should be dot 4 and I replace with sae30 will this also be damaging ? 👍
less so than vice versa IMHDO ... lot of additives in the DOT4, which some rubber compounds won't like :(
But if the cylinder is not original and the seals are originally used with dot4 the seals will be ok with dot4 and Sae30 but you need to clean brake lines and axle cylinders right through , before re bleeding with sae30.
yeh .. flush the lines and axle cylinders right through with sae30
P
Popeye
Right then 😵‍💫 I got hold of some 32 and used that for the time being ! Once I’d flushed it through I’ve suddenly got resistance in the brake pedal..👊 not at all like new car but definitely make progress. I’m thinking of getting a new master cylinder just to make sure as it’s a bit intermittent. I’m getting a few solid pumps of the brake pedal then it becomes free for 2 pumps and begins to build pressure back up. I’ll let you if it stops once I’ve fired the old beast up 😆cheers lads
keep bleeding ... could well be lots of air in there ....... or put a Schraeder valve in the reservoir cap and pressurise it through with a couple of PSI of air pressure in the res. ....... just make sure the res. doesn't run out of fluid .... Gunson used to do a DIY pressure bleed kit with a selection of caps other wise
still do BTLs
If I remember rightly the 4000’s had a fair bit of propshaft clatter when slipping the clutch to pull off! Keep up the good work👍
If you are going to spend money on a bleeder, the air/vacuum unit rocks.
Canal Navvy
Canal Navvy
Matbro, the now extinct materials handler manufacturer used to cheerfully fit brake reservoirs with "use dot four" moulded into the lids on machines built with tractor axles that couldn't have dot 4 in them.
Difficult bleaders do sometimes respond to having the fluid pushed in at the axle end and drained out of the reservoir ..... same as they are factory filled.
Wondering if the non-return valve on the master cylinder is playing up, the one that let's fluid from the res into the cylinder and closes at the beginning of the stroke 🤔
Exactly that, and early thwaites and benford used the same lids, even though they couldn’t use dot 4!
like that Mr @Gecko :cool::cool::cool:
took me a couple of minutes to work out WTF the tripods were for :LOL:
That's where I was heading when I asked if the level wasn't dropping.
If the peddle is going down repeatedly, but the level isn't dropping, the fluid must be returning the the reservoir.
If the level is dropping, but you can't find the leak, it'll be draining into the axle.
You're doing better than me - the unit I used had no accessories (none left anyway). What are the for?
P
Popeye
still do BTLs
still do BTLs
