P
Popeye
I seem to be on here every night
not the best at stuff like this so bare with me ! It’s 1994 ish 4 tonne dumper. No resistance in the break pedal whatsoever. I’ve had the master cylinder off and apart and it seems one of the outlets isn’t letting much fluid through ( might be blocked ) it’s not leaking from anywhere and the seals look good. I’ve managed to bleed the fluid up to the front axel but the pedal is still soft. I decided to cap off the rear brake outlet from the cylinder temporarily so I could concentrate on the front hoping that this would solve the problem but unfortunately this hasn’t worked. I’m kinda hoping it’s the cylinder that is the culprit and not the brakes in the shafts. Any advice would be appreciated
