She's arrived this morning.....
So the old trailer wasn't suitable so new 1 bought and collected today.
Make sure your ramp stands touch the floor - I had a Brian James plant trailer and it was a very nicely made piece of kit but the props floated in mid air with no way of adjusting and the trailer kept cracking across the middle. It has put me off them tbh, but hopefully they’ve modified the design.
I will check when I take it off as put it on there the wrong way around
Well both really😁 but the trailer is all I can afford at the moment 🤣
My 1st impressions were it's a beast. It looks rock solid.
Jockey wheel a lot better than my indespension and ifor trailers.
Ramps were smooth and lock easily.
Looking at it I well believe it
Has it got the auto-open wheel?
Ours didn’t last very long and was swapped by the supplying dealer for a conventional ribbed version with an optional hinged clamp attached to the hitch casting. That was better but the threaded bolt/handle that released and tightened the clamp was a really puny thread, and subsequently also failed. Not a very easy thing to replace/beef up either.
Yes I think it has. It automatically retracts on the last couple of inches
well they shouldn't have much anyway ;):giggle: ... will only be designed to take the legal/design limit :rolleyes:
But it's a pain when you are trying to shuffle things on the trailer and they collapse
Had it happen on a 3.5t ifor plant trailer with a 1.5t digger. Moved it to the front to to squeeze something underneath it without dropping the ramp and the jockey wheel crumpled
It’s a plant trailer, it is likely going to suffer non-perfect loading from time to time.
It’s frustrating that jockey wheels in general are pretty crap, and difficult to maintain. In my experience they tend to eat the bearings right at the top, and almost never have any way of greasing said bearings.
Knock the pin out, open it up and slap in the grease. Often they just need another shim washer in there to bring the bearing back into play.
so fit a prop :p, couple it up ... or don't complain when the over stressed jockey gives up the ghost :rolleyes:;):( .. not really designed for handling loaded trailers, other than support whilst parked/coupling/uncoupling
There is a company on Facebook advertising hydraulic jockey stands rather than wheels with a bottle jack to lower rather than screw thread
But even a perfectly loaded tandem or tri axle trailer will have a lot more than nose weight on the jockey wheel just to be able to get it off the hitch.
A perfectly loaded trailer shouldn't exceed the towball weight quoted by either the trailer manufacturer (probably won't be able to find that one) or the vehicle/towbar maker. It'll probably only be between 100 and 150kg so not a huge ask for a jockey wheel but yes they are crap in many cases.
