Ripper
Got a few tree roots to grub up (about 8 acres) of self seeded trees that have been left for at least 20 years so thought I’d knock up a ripper this afternoon got some 10” pipe of a job
And a lump of 1” plate to make the hanger
Drew out the shape I had in my head:rolleyes: and cut all the curves:love:
Then joined up the curves with straight cuts to complete the hangers then stuck them together
Next job make the ripper, found a 40mm plate that was going spare and drew a Tyne shape on it
Then burned it out free hand, bit rough but got the shape I was after;)
Maybe a bit long at 39”
:unsure:but will be easier to whip a foot off the bottom than stick a bit on(y)
Well had a rethink already:unsure: going to make the Tyne with a wider profile ie. more metal at the back so I can create some ‘rip saw teeth’ in the back bit like this
https://www.ebay.co.uk/itm/Excavato...488514?hash=item1ef458f142:g:liMAAOSwa2tcYGYr
Having a bit more ‘body’ at the back (serrated or not) would also give a better fulcrum to lever against when crowding. Maybe think about chamfering a bit of an edge on the pulling side if it is primarily for roots too.
BertB.
BertB.
would those cheeks not have nested like this Mog .....I hate having odd shape off cuts :rolleyes:
Davedb
No such thing as od shape off cuts they allways make a gusset for something :p tidy work have you enoght plate for me to make one:giggle:
Know what you mean .... but always easier trying to nest into a rectangular lump than a weird shape:rolleyes:;)
Didn’t take any pictures of the cutting or welding but didn’t take too long;)
But here is the finished article
Had it good authority (Dan) that ‘it should work’ :unsure::ROFLMAO::ROFLMAO:
tha's gonna scare the bejeezus out of several acres of trees :ROFLMAO::ROFLMAO:
Still wouldn’t fit 600mm wide plate and my pin centres are 450 with 80mm pins
Still got plenty of plate comes in everyday(y)
guessed there must've been a reason :rolleyes: ............. you lucky lad :sick::cry:
Davedb
What thickness do you want the Tyne is 40mm the hangers 20mm got plenty of 20mm even got a few slabs of 100mm
20mm is always handy I’ll have come down for a nosey what else you’ve got:p
Well it works a treat the biggest one so far was a oak tree stump with a diameter of at least 18” just went full depth of the ripper on 4 sides of the stump as close as the head would allow, just pop it out of the ground then using the teeth on the back cut the small roots and soil off to back fill the hole
This was the first of many
BCF37131-5EDC-4F05-9EC3-4B81F83321ED.jpeg032FE098-5352-4345-9F4B-DDFE6FFB7C75.jpeg83427D17-F4C4-441C-B151-5940471A9934.jpeg
Now on to phase #2:whistle:
A land rake to pull all the roots into a pile and ripp a few of the smaller ones out;)
Made a start:) got a few FLT tines out of my pile of scrap (ones that I’ve bent:() cut into 20” lengths
Got 9 of them, so got a 8’ length of 10” pipe and cut square holes in both sides so the tines slot right through and welded them in
Just need to weld the head on and finish welding the tines in;)
Then I can give them roots some hell:mad:
:eek: oh you bloody vandal :cry: :LOL:
what's that old boiler tube out of Mog :unsure:
Looks like they're at least making the sacrifice to a good cause :rolleyes: ..... them tree roots must love seeing you arrive on site :LOL:
bet the local bird life must be loving you turning that lot over for 'em ;)
Ripper looks the bollox Boyo :cool:
