Was down by Whitchurch today collecting my latest purchase from fleebay and it turned out to be the yard of these guys they had some big scanias sitting about the place.
If you look at the axle articulation of his trucks looks the same to methought the Tatras were famous for their mono spine chassis with integral transmission ?
was looking at some of the chassis in the workshop section Mog ... looked conventionalIf you look at the axle articulation of his trucks looks the same to me![]()
Yes cause they are scania’swas looking at some of the chassis in the workshop section Mog ... looked conventional![]()
Look in the tatra section![]()
what you doing with the V8 m8what size is it?, is it out of a loading shovel got a drop box on the back of the gearbox
It out of some kinda airport tug which was 4wheel drive.what you doing with the V8 m8what size is it?, is it out of a loading shovel got a drop box on the back of the gearbox
Can’t tell from the picture looks like separate rocker covers so scaniaIt out of some kinda airport tug which was 4wheel drive.
What tractor are you going to use?Yep perky V8, 540 it came as standard in a Massey Ferguson 1155. The limit is 9 litre for the 4.5T super sport class. The 540 is circa 8.9 litre. It came with a Allison transmission but not sure if I can use it yet. Also has a 4x4 transfer box that I will need to remove.
a 'strong' oneWhat tractor are you going to use?
