Unless the mod is airbags!Suspension lift etc will probably mean it's safer to downgrade it. End of the day no modded 4x4 is as stable on the road as when standard.
To be honest Doob, I didn't look at the website, but a standard un-modded Jimny is rated for 1300 kg. As Gaz says, they've probably downgraded the modded ones because of the mods. Possibly also so no-one tries to tow 1300 kg over a field then complains because it gets stuck. Bit like the army downgrading their trucks compared to normal on-road use.Specs on that conversion site said 750kg?
an sj413 was my first 4wd, I felt like a king at 18 with the local skank by my side![]()
The other thing with jimnys is unlike the old sj that went before them they are not as strong built in the driveline. Good set of knobbly tyres and get rough with them uj's can let go and thats without over a ton on tow. The beauty of them off road is they are not over engineered and heavy as a result but if you want one to last you do have to treat it with a bit of respect.To be honest Doob, I didn't look at the website, but a standard un-modded Jimny is rated for 1300 kg. As Gaz says, they've probably downgraded the modded ones because of the mods. Possibly also so no-one tries to tow 1300 kg over a field then complains because it gets stuck. Bit like the army downgrading their trucks compared to normal on-road use.
I’d have the pick up body, no suspension mods, and keep the rated tow on the road. Even as standard they take a bit of stopping unless you go full “one life live it” weekend warrior.Suspension lift etc will probably mean it's safer to downgrade it. End of the day no modded 4x4 is as stable on the road as when standard.
'One life- though driver clearly doesn't have one!'I’d have the pick up body, no suspension mods, and keep the rated tow on the road. Even as standard they take a bit of stopping unless you go full “one life live it” weekend warrior.
I always liked Conrad's (@Mintsauce) slogan on CEF ..... " One wife - Livid "'One life- though driver clearly doesn't have one!'
Perfect for the back of a Land Cruiser.I seen one the other week, "One life - don`t waste it fixing landrovers" on the back of a disco![]()
Sums up my wife about me most the time hahaI always liked Conrad's (@Mintsauce) slogan on CEF ..... " One wife - Livid "... always thought it was a great play on words
Nice tractorWaited since October. Apparently they won’t see any more of this model until next October! View attachment 32511
Any more pearls of wisdom for us?This isn't to try and compensate for a loader in particular.
