R.Sanders Plant
Not quite as happy as I'd hoped....
Not that sadly :(
take the tub off and mig a panel into the back .. looks pretty flat ... cut the crap out first though .... could even sikaflex a panel on .. couple of pop rivets to hold in position, while it goes off ;) ... annoying but do-able
Already got a pal on it ;)
Do you never mot check online, see how many years rot has been on the advisories?
That's the thing.... Chassis is mint and zero corrosion advisorys.
It's actually spot on..... Bar this one bit behind the cab :(
The caretaker?😉
If I had time, a passport and Coof Coof wasn't on I'd be over to Rough Diamonds purely for the craic. Good man with my sorta outlook!
The chassis on mine is mint, barley anything bar surface rust. But behind the rear wheel arches has completely gone through
Two holes the size of diner plates
A mates one is awful rust everywhere including the axle springs wishbones the lot
It looks ok on this, but I guess yours doesn’t come on a roll!
1st time I saw him on li I was wtf...till I deciphered it 👌🤣
