Dumper truck help
P
Pag18
Hi Having looked at your great forum can anyone offer some advice. I have a 3 ton dumper and I am not sure how to remove the center pivot. Also we do not know what make the dumper is, the front axle is Newage Coventry and the gearbox is Newage 85m engine lister 3 cylinder. Please see attached image
From the photo, I guess there would be another cover plate at the bottom, and bearings, and a pivot on the rear axle as not evident that it has an articulating centre joint, not from this angle anyway!
P
Pag18
The first image is with the bottom plate removed. Many thanks
We do not know what make, have you seen the images I have posted for another member. Many thanks Graham
Have you not got an better images, from a bit further away?
Looks like someone already had a go with big hammer and chisel!
Axle stand the rear half all round, tip the skip, axle stand the front at the skip end, the skip weight will tip it forward, the pin floats between the upper and lower plates, and in the bearings, I haven’t got a TT picture of the centre pin kit! Once the pin is out you can use the steering ram with care to separate the two halves, the swinging rear axle will need blocking between axle and chassis.if you can get parts first you will see how it fits.
The later model had a pinch bolt on the side of the bolt about half way down, can’t see it in the photo it would be on the other side!
don't hammer the pin .... IIRC have done one of these many years ago ... put a good jack under the pin and take enough weight to be 'noticable' .. short tube over the top with a good solid plate on top of it and hit the beejesus out of that ... repeat jack, etc. and will need a drift or short spacers as the pin progresses .......... best done on a good, flat, solid, floor. ;)
tell a lie - just looked .. was a Thwaites with the wobbly top link ... but as said all jacked out from below ... top pin using a long drift .... way easier to whack it from the top than trying to sledge upwards
IMG_2673.jpg IMG_2671.jpg IMG_2672.jpg IMG_2674.jpg IMG_2675.jpg IMG_2676.jpg
View attachment 29541 View attachment 29542 View attachment 29543 View attachment 29544 View attachment 29545 View attachment 29546View attachment 29547
How do you catalogue/find your pics years later Gra? Got some filing system/naming setup?👏
year and month LL and a reasonable long term memory ;) don't ask me WTF I was doing last week though ............................'til next year :ROFLMAO::ROFLMAO:
one day week month :unsure: I'll scan all my paper pix into the system ......... they go back pushing 50 years 'til I went digi in about 2001 ..... and there's some pile of them:rolleyes::oops:
