interesting idea
just tripped over this on FB MP
so what you might say ..
" Heavy duty pipe wrap
£3 · In stock Listed in Leominster, England
Condition New
Keep your pipes out of harms way with heavy duty pipe wrap made out of water pipe. Only comes in blue £3 a meter + postage "
enterprising use of an old D,S&G
wonder HTF he keeps it straight and grips it tight enough to slit it ... collet chuck 'praps ???
Doing it in a lathe seems slow
I bet it would not be that hard to make a tool that you could pull it through albeit with a fair amount of force and it do the hole lot in one go
If the tool is in the chuck, then he’s only got to hold it to stop it rotating. The right angle on the tool and it would feed itself.
Steve
I did this a while back, I wouldn‘t need enough to want to bother with power feed.
