Pressing issues
what on earth is the bar for in front of the main press base? it has a Vee on it and a pair of spindle pins🤔🤔
That be for checking your shaft is straight. You wouldn't want to come away from the press with a bend Inn your shaft
is that one of those silicon pop up bowls presumably for the dog's water hanging on the wall Mog? .... ... very clever design idea those pop up dishes/bowls/measuring spoons/cups :cool:
hell of a nut sat on the press :oops:
Mycock 65t Press.... I've one the same :love: And yes for checking straightness and also very handy to work on small rams.
I’ve obviously got no idea what that is for. However, let me know if any other presses cross your path as I want/need one….
@doobin - how’s that one you bought? Show us stuff you’ve bent!
Nice one .130 deffo the one to get...looked at 122 a bit back glad I didn't bother now .
Still on the to buy list 🤦‍♂️🙄
I’ve fancied one for a while, just need the time to chuck it together and have a play!
I (finally!) opened it up to find the manual/supplied fixings as someone on Arbtalk had mentioned swapping the supplied nuts with nylocs and I wanted to get the right sizes bought - it turns out that it is supplied with nylocs so I either imagined it or someone was talking bollocks (or most likely a combination of both!).
Arbtalk ..someone talking bollocks?🤷🤣
I just assumed it was an adjustable cigar holder for when you need both hands to work 🤷‍♂️
Don’t be daft!!!
(It is largely assembled, I’m just waiting for a load of steel to nail together a super-stiff forkliftable frame to mount the rails on before I mess around truing everything up).
What kind of ‘frame’ are you wanting would a FLT mast work🤔
If it was 6m long it might!
I’ve given a cutting list to the local stockholder tbh mate. It needs to be as flat as possible and I don’t have your skills to modify anything and expect it to work!!!
Don’t be daft!!!
Good thinking...that was worry how to shift it once assembled as I'm not bothered about trailer and don't want it on my Ifor full time. I'll watch with interest.😌😌😀
