WPD are pretty good on the whole unless your mouthy.
they were very nice guys Rory ... and got well looked after in the refreshments dept. ....... couldn't fault them TBH ....WPD are pretty good on the whole unless your mouthy.
cheers Boyo ...... it's a canopied 8015That is a slightly different lay out to the newer 8014 as the one I drive has the battery under the bonnet on the right hand side but if the cab mountings are the same and you do want better access or to find the original started wire then undo the two big bolts by the pedals and a couple around the floor which will become apparent and the whole cab tilts up on gas struts.
5 minutes and you have perfect access to the engine bay and far better access to the underside of the dash than going in through the top will allow
cheers Gaz ...... sound advice ... it is just about accessible ..... might even fit a new spade. While things are in bits give terminal on starter solenoid a nip with pliers, common for coming loose (that'll be your next starting problem if you don't). I'd do away with immobiliser tbh it's not like it spends time away from home on hire where it might vanish
canopy'd not be an issue to remove TBH..... panel behind the seat exposes the starter, but has very little in the way of movement to go looking for the original starter cable ......but it's going to get a new Thatcham jobbie ...... it's paid for and should be here Tuesday hopefully ... will get a serious dose of silicon in the appropriate places going back in ..... TBF to Ollie, it's lasted 11 years ... and he was very apologetic.... 's one of them things ... could've gone on him in the middle of a job .. and that would really have been a PITFA ... or me the other week ...... but I'd have just picked it up and slung it out the way
No tip up cab/canopy on druids model. To be fair though its only 4 bolts, leccy connecter and clip on hyd filler and you can lift cab/canopy off. Was handiest thing about mine when i had it and wanted in somewhere low with summat bigger than micro.Sorry Canopies what I meant
The one I drive has the solid left hand console though so might be different I'm sure others can confirm. But with the canopy up it lifts the seat side console and everything completely exposing the engine
sadly this is an unbolt it job .. lift it out the way (not an issue) then unbolt the engine cover ... if the plate behind the seat, covering the starter / engine bay had a slot instead of a hole for the throttle cable to pass through, life would be 200% easier .. if it does have to come out, it will get modified to make life a hell of a lot easierSorry Canopies what I meant
perfect access is overdoing it à bit if its like the 8014 I had for a few years but its certainly betterThat is a slightly different lay out to the newer 8014 as the one I drive has the battery under the bonnet on the right hand side but if the cab mountings are the same and you do want better access or to find the original started wire then undo the two big bolts by the pedals and a couple around the floor which will become apparent and the whole cab tilts up on gas struts.
