Anyone have a tool that cuts and chamfers that is not a grinder, disc cutter or old saw and file
There's one I've used before that's based on visegripsAnyone have a tool that cuts and chamfers that is not a grinder, disc cutter or old saw and file![]()
thought you were an operator Stu .... not a plumber .... must do a lorradrainage to warrant 160 quid on one o' theyThere's one I've used before that's based on visegrips
It cuts and chamfers at same time and also good at holding those pesky little bits as well
I've just bought it on eBay as it's the cheapest I've seen plus had apply code and had 39 quid nocked off too from 195 quid
Did this lot last week 2 houses worth mirror image so measurements on first one worked for second onethought you were an operator Stu .... not a plumber .... must do a lorradrainage to warrant 160 quid on one o' they![]()
fair play ..... it's the way to keep busy ... AND get asked backDid this lot last week 2 houses worth mirror image so measurements on first one worked for second one
Normally cost about 250 to 400 on net to buy so that's cheep but yes do a lot of drainage as well
Used to do a campsite that would buy direct from polypipe and have 50 pipes per bundle of 6m long 110 pipe delivered at a time
Never say no as it keeps me busy when work is quiet for everyone else that doesn't get out and graft
I asked this years ago .... if what you have is any good will you let me know - we do a few km of pipe and its associated cuts every year and at moment use stihl saw and grinder but there has to be a better way.There's one I've used before that's based on visegrips
Used the same tool years ago works well leaves a slight chamfer on off cut side due to way it cuts that still easy enough to push in if you wantedI asked this years ago .... if what you have is any good will you let me know - we do a few km of pipe and its associated cuts every year and at moment use stihl saw and grinder but there has to be a better way.
Our pipe is 100mm as opposed to 110mm though.
That's the 1 I was looking atThere's one I've used before that's based on visegrips
That mini router not worth the money then?tried a few chamfer tools over the years, have a router with a jig thing built to it that cuts and produces the chamfer(still in shed), round ones that snap your wrist. The one I've had for couple years now which works great on the impact gun is this. Can't remember where I got it from...
Drill Chamfering Tool 72-110mm | plumBOSS Australia
Drill Chamfering Tool 72-110mmwww.plumboss.com.au
I cut the pipe using a grinder, to get a straight cut I cut off the end of a pipe (so you have a good end) cut a slot out of it to make clipping it onto pipe easier then slide it to the cut line and follow it round with the grinder.
Quick and no pissing about with files etc
i have one if you want it cheap.That mini router not worth the money then?
There were a couple of good videos on YouTube but tried finding them without successI asked this years ago .... if what you have is any good will you let me know - we do a few km of pipe and its associated cuts every year and at moment use stihl saw and grinder but there has to be a better way.
Where did you find the apply code as don't use ebay?There's one I've used before that's based on visegrips
could be time to startWhere did you find the apply code as don't use ebay?
Found the cutter just need a code if 1 is available lolcould be time to start![]()
