Kitchen and Wade Drill query
Next question - I’ve chucked some wires into the lathe and can get it to make noises if I push in the buttons inside the electrical panel, but the controls on the front don’t do anything. I’m no electrician and I’m certainly not getting heavily involved in this as I will definitely die…
What it the little silver jobby circled below? It seems to spark at random (which is rather disconcerting!)
Is neutral hooked up?
Can't see. The control side might need it
deffo I'd have thought if lo-volt, but can't see a Neutral post , so might just be transformed straight down from 440 .... a clearer pic would help a lot
see if the orange bit (circled yellow) will move inwards with a well insulated screwdriver MB .... looks to be the main motor contactor ... pushing it home (if it's a moving type) should fire up the main motor
Yeah, push that and stuff happens.
No - I can’t see where to connect it so left it out of the mix. It could well be the issue though!
Is this supposed to be this fierce?…
as in the motor fires up ???
may well be no neutral and just three phases ... only need neutral to split 240 out off phase legs ... lot of continental stuff is just 3 legs and transformed down to whatever they want
"fierce" ..:oops::LOL:.... stay well away from that MB :oops::oops:... has the capacity to do some serious damage 🥲 - has shorted to case - new one required ....
disconnect from supply ...
leave a while ...
wear good thick rubber gloves and earth it with a jump lead to be certain it's fully discharged ..
then inspect for info/details/credentials ...
buy new one and fit ;)
on edit
should find a new capacitor easy enough ..... once you have the details .. treat that with the utmost of respect that is some arc
Rob65
Monkey Business,
Do you want some tapered shank drills for your machines?
I have a collection here that are duplicates of the ones I use. I wouldn’t let them go for £200/te but I also know they are not made of gold either.
If you might be interested I’ll dig them out and count up what I have spare.
Rob
Monkey Business,
Rob
I might be also, up to MT3
leave a while ...
on edit
I’ve been in touch with my electrician - I’m not going near it again until he’s sussed what’s going on!!!
Monkey Business,
Rob
I’ve got a load of tooling that came with this kit that I need to pull out and see what’s what, but yes, potentially please. I’ll get my head around what I have and see if any gaps can be filled - thank you!
Where’s your sense of adventure🤔 stand in a bucket of water (bare feet obviously) and poke the offending capacitor with your todger just to confirm it’s fault, don’t want you wasting good money if not needed😂😂
That’s a bit specialist, even for you (whatever floats your boat though I suppose!).
What do you put in your search engine to find those videos by the way (so I know what never to type, ever!!!)?
Touch it with the back of your hand ;) that way if live your hand will recoil away.
which hand?🤣
dropped cover plate off big 3ph db once..undid last screw and it slid and hit the buzz bar...hell that was a helluva flash...😳😳
which hand?🤣
aye 3 ph is to be respected - big time.
stripping my shop I was sure i had a dead board in front of me, having knocked all the breakers off at the main dis. board ...... wrong ... bloody leccy had run this one straight from the meter/main isolator .... helluvaflash ... went back to source and pulled the tails, with the main fuses pulled ... wire tied or not they were coming out :oops::rolleyes: ... left the lights and alarm connected .. everything else killed ..... not to be ****ed with
240v bad enough..always kin happens..new pair of knipex..and bam.😣😣
Rob65
Im crazy busy with work for next couple of weeks. As soon as I get time I’ll dig through me drill collection and let you guys know what I’ve got.
Rob
well this is my attempt at wiring took me an my brother 3 days to complete
but only cost £1k all in with 30 led strip lights👍 (have got a few left over😳)
switched from one location? ... takes a lot of time running singles out, or have you run 2 / 3 core back from each. there's no short cuts to a decent job MB .. looks tidy ...... no overheads or higher levels??
