If you wanted a 1.2 wide one then you oreded the wrong one. Gh1054 translates as 10ft long by 5ft4in wide.
It's the length of the rear drop down loading skids, there is four options on the gh1054 two full width then two different length of sliding skids
Now that's what I call a joint pit ,🤣
If you’re that close to the limit that 20cm longer on the skids puts you over then you’re too close anyhow! 😱
I wouldn’t be without the full width ramp on my gh1054- so much easier to load all kinds of machines.
Apparently a 30kg difference between the 1.45m and 1.2m skids that's a fair difference
f**k that. I’ll just have a dump before I drive off.
It's more the principle, if you order something, it should be what you ordered.
The 8026 is heavy so every kg counts, don't get me wrong I'm not going to go, to the extreme of cutting every unused part of thread off the ends of every bolt on machine and trailer (although could save a good kg or so 🤣)
Might get it on a bridge at some point and see what the total is now whether that is trailer coupled or uncoupled is another Can of worms
well if you want to know what the GVW of said trailer is ... the latter unless you can get a letter from DVSA to say you can add the nose weight :ROFLMAO:
Well not today's job, but yesterday's..... not often I do any service work other than what we sell now, but the guy building my house asked me to service his little Volvo....... and I'm trying to get him to come back soon😄
First time using the 8026......
Tracked off the trailer and across the site, literally first pull to do some grading and quickhitch pipe pinched in the tipping link pin bolt and burst 😭 to be fair it's very tight in the hitch and these things happen
All sorted, at least for now, so will see how it holds up but currently both pipes tied up to the tipping link not convinced it's going to work but the hose fitter thinks that's the way 🤔
Thanks to Ollie gunns and Neil at nasco for the advice not that the fitter was that interested in the opinions.
At this rate seem to be giving doobins leaky bobcat a challenge
Thanks to Ollie and Neil at nasco for the advice not that the fitter was that interested in the opinions.
Should have got a Tak 😂
pain in the arse for you but hopefully just a teething problem…
The hitch is small, I'd say probably smaller build height than the manual hitch on the dx10z.
Always going to be teething problems but at least they have been sorted quick, on the plus side the 8026 is great, only done a bit of grading and little muckshifting so far but happy with it
I like it but that granite is the stuff of dreams. It’s when you get bastard stuff with no faces dropped off and customers expects a top job of it 😂
is it Dartmoor granite out of interest? Looks more Cornish 🧐
Oh trust me, it's far from the stuff of dreams
Isn’t there something about an applied load? As in if your truck is rated to have 250kg nose weight you could have 3750kg behind you- assuming you got load distribution spot on….
