Help please, bomag bw 100 roller, parts and advice needed.
Richard Hunton
Richard Hunton
Hi all
Just purchased a bomag bw 100 2
It doesn't vibrate at all, apparently its a solonoid 🤔 anyone any experience of these things, diagrams and suppliers of parts for them, I've a feeling I've bought an absolute pup.
Not only but also it won't turn off on the key as the stop solonoid wiring is mangled / bodged. I assume it needs a new solonoid if anyone can point me in the right direction
Thanks everyone
Richard Hunton
Richard Hunton
This would be it
Richard Hunton
Richard Hunton
Get a good wiring diagram Rich.... My gut feeling would be check the wiring first..... See if it's got hot?
I'm going to take my multi meter and have a poke about over the weekend, I'd like to think it's a switch or connection, but my luck doesn't work like that 🙃
Richard Hunton
Richard Hunton
If it's any consolation the stop solonoid not working is a fairly common thing with that age bomag.
Poor thing doesn't stand a chance 🙄
Hi all
Thanks everyone
Check your firing first, I have one that had broken wires in the joystick
I may have a used but working stop solenoid in the workshop.. if needed 👍🏼
Richard Hunton
Richard Hunton
Dave that would be excellent, where abouts on the roller will this solonoid be? I was told by the lad I bought it was under the seat, all I've found so far is the water tank
Oh sorry I was replying reference the engine stop solenoid.
Kubota engine stop solenoid, take off the red wire put a live feed to it see what happens, vib solenoid I think is front right hand corner of the engine bay when sat on the seat.
Whilst I think about it I have also driven a few of these of similar vintage with vibration wired into various different switches on the dashboard, even the hazard light switch so they must have quite common wiring problems
Richard Hunton
Richard Hunton
That's also a big help, if you let me know how much you want and send me some bank details I'll sort it, where in the world are you
It’ll either be the switch in the lever or the solenoid . My 80 plays up the same . One of the guys that works with me got so hacked off with it always sticking he fixed it himself ! I will ask him tomorrow what he did
Richard Hunton
Richard Hunton
If it’s the lever switch trace the wires back, put your own switch on the dash and connect it up, ( on/ off)
I've replaced the switch as the old one was clearly put it by a lunatic.
It works now ......but it will vibrate for a second or 2.....stop vibration for a second ......then kick back in for a couple of seconds......so on and so forth
I assume it must now be down to the solenoid
Do you know if I could swap it with the drive solenoid to rule it out 🤔
