To clean or not to clean - that is the question
muddyone
muddyone
Hi All, so my kx71-2 is in need of new hydolic cables - opened up the floor and wowzers-think it's the first time in all its 5000 hours. So is it a brush/trowel and oily rag? Or can I get in there with the jet wash? - obviously there are some electrics I need to watch but everything else should be up to the job?
muddyone
muddyone
That was my thoughts.. Just didn't want to make a rookie error. Steam above jet?
Steam it, there is a solenoid valve to be a bit cautious around.... Just avoid any wiring.
Jetwash won't remove oil, steam will. Hire one if you have to, it'll make the job 10x easier. You can always turn the pressure down around anything delicate too.
Steam far better for oily greasy stuff but i tend to cold wash with detergent and then use steam for rinse. If you go straight in with steam you'll bake sh*t on unless its oily stuff.
All the panels come off, take them all off it will give a lot more space, and will be easier to get all the crap out.
