Site Fuelling
Alexmac
Alexmac
I have a fuel proof 500litre tank with a electric pump, it’s spot on.
Cyberprog
Cyberprog
God, I am so glad I'm clear of the generator game these days. Used to wind up being the diesel weasel on big events, dragging a Bowser round filling sets!
Really could do with a bigger tractor to pull it, with it’s full it has the tendency to shove you some times. Will get a photo of the inside it got a 2 inch water pump with electric start and 1” hose real with full flow fuel filter.
take it that is multi baffled ... be bloody handful otherwise :eek:
Reviving this thread,
How are people filling there mini diggers?
The micro and the track dumpers are fine easily filled with 5l drums, mostly easy access very little in way of spills.
Having put 75l in the 2.5t this week is growing old already using 25l drums and trying to stand on the track and blade while trying no to spill any, was similar issues before with the dumpers on site.
I'm going to pick up a nozzle for the drum but as they don't have a vent can see it being a pain.
Don't really want to go down the route of a 200l portable tank with pump due to having to keep taking it out when not needed.
Are the cheap 12v portable ones any good or any recommendations for something a bit better, did see Milwaukee do a M18 transfer pump but it's only rated for water
before I bought a dedicated transfer pump I rigged up a 12v injection fuel pump on a dip tube into a drum ... IIRC 'twere a Ford one, but any one'll do
these shift a fair amount of fluid pretty quickly and for 25l drums'd be pretty rapid ... fine for petrol or diesel .... can also get these in drum submersible pumps, but a lot slower than one of the above
If I`m using 25l drums, I use a 12v transfer pump, only problem you need access to a battery.
This type of thing
Don`t know why in that picture they got the delivery nozzle on the suction pipe :rolleyes:
This is mint - I would buy one tbh!
Cyberprog
Cyberprog
before I bought a dedicated transfer pump I rigged up a 12v injection fuel pump on a dip tube into a drum ... IIRC 'twere a Ford one, but any one'll do View attachment 27958
That looks like a standard in-tank pump. They are cheap as chips. Put one in my discovery. Sod paying £150 for the whole thing when the pump inside can be fixed for £15!
Cyberprog
Cyberprog
That looks like a proper job. Couple of hydraulic connectors on there and you can make an extension piece too.
This type of thing
Piusi box same idea but all in a box to keep it tidy. I have one but tbh for the amount of fuel ur using more hassle and faf than enough. Either get smaller drums or don't put as much in them be your easiest option imo.
How about one of these, I have one left and would do a good price on
100L nice and compact and easy to lift
