Steve Trott
I believe the Kubota range of tracked dumpers are rebadged hinowas
I see the listing is no longer available. Does seem cheap, especially the way everything else is just now. Wonder if it was a scamtalking of Kubs ........https://www.facebook.com/marketplace/item/1047940412281270/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%226964512235330949981%22%2C%22mf_story_key%22%3A%22227382822060231231%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A227382822060231231%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A0%2C%5C%22ranking_signature%5C%22%3A3941846775823859712%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A5.499254918936e-6%2C%5C%22upsell_type%5C%22%3A807%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%226964512235330949981%22%2C%22lightning_feed_ranking_signature%22%3A%22999915906026962944%22%7D
£4.5k + VAT
"Kubota KC70 Tracked Dumper (2015) Diesel Expanding tracks Twin speed tracking Good hydraulics Tracks good Only for sale due to new purchase "
didn't think this was dear ..... but I know sod all.... does anyone these days in the s/hand market ??????
Bugger the dumpster, did you see all the anvils in the background!!talking of Kubs ........https://www.facebook.com/marketplace/item/1047940412281270/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%226964512235330949981%22%2C%22mf_story_key%22%3A%22227382822060231231%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A227382822060231231%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A0%2C%5C%22ranking_signature%5C%22%3A3941846775823859712%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A5.499254918936e-6%2C%5C%22upsell_type%5C%22%3A807%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%226964512235330949981%22%2C%22lightning_feed_ranking_signature%22%3A%22999915906026962944%22%7D
£4.5k + VAT
The vh range is more aimed for the professionals although the other range will do it not every groundwork's wants levers and brake handles to drive . That said we don’t really offer a competitor high tip vh range so your limited for choice.
After using the jcb for a day I can confirm it is rubbish.
The lumag vh850 HT is too wide (800mm) and the specs don't mention skip volume, load capacity in kg is almost irrelevant .
Not a fan thenAfter using the jcb for a day I can confirm it is rubbish.
Well that’s no use!I had a proper go with a petrol slanetrack this week. It's got to be the best one going at the moment with the 500 litre skip and the high ground clearance.
The only thing I would say is the skip is a bit thin and doesn't tip very steep, It takes a few attempts to get it empty.
does look the Mutt's ......... but at a serious price i'd guess
Guy local to me has one, really rates it. Think 9 or even 10 k.does look the Mutt's ......... but at a serious price i'd guess
For a <700mm wide high tip it does have the second highest capacity I've seen so far.
I have a petrol messersi turning with a load on isn’t an issue I know what you are trying to get at & I don’t think it is particularly fast but I don’t have any thing to compare it with.For a <700mm wide high tip it does have the second highest capacity I've seen so far.
Slanetrack is 0.4-0.5m3
Your Messersi is 0.27m3
TCP is 0.25m3
Jcb is 0.2m3
One thing that concerns me with the Messersi tc50 is the low power of the engine. What does it turn like with a load on and is it slow?
What I like about my Lumag with it's gear system is that you can get it up to a fast walking speed. It's very quick on turnaround, but you have to really 'drive' it- throttle control, gear changes, you're always pulling levers. Goes up nice and high (way better than the hired Hinowa, which wouldn't even reach over a Transit tipper!) and tips well forward- I've never had to try hard to get it to empty.My TCP is about half walking speed when its flat out.
The slane goes a good bit quicker, maybe full walking speed but you would have to stand on the platform for that otherwise you'll bang your shins on it.
Slane, 4.5 km
Messersi tc50, 4.2km
TCP, 4 km
Looking at that there's not much in it
TCP is 0.25m3
Jcb is 0.2m3
