Which 5-6t Class machine ?
U48-4 Kubota....
Fast, Powerful, less reach than the 57 but I like em more. Your also well underweight for the tilty so I guess you could get a weight slice on the back.....
Mine had Cat 8t buckets on and a 3cx grader before anyone pipes up..... threw them about well but obviously a little tippy for the uninitiated.
The jcb 85z I had was absolutely terrible, needed full revs just to move it so no chance of oil share on that!
The 57c is pretty good, I’m one for making a machine do everything at once and I don’t complain too much about it, yeah I’d want more power/flow but then I should of picked the bigger engine - but I was being tight and didn’t want to burn more diesel for no real benefit. If your ever in central England let me know you can have a good go on it 👍🏼
U48-4 Kubota....
Ive remember you saying that you liked the u48 .... the plan is to replace the 8t and poss the 3t as well with a 5-6t - I use someone to move the 8t at the moment and thought the way the work is heading I recon I could just about get away with 5-6t machine and swop the current 7.5t hookloader for a 12/14t and move it on that..... but u48 might be a bit too small for what I need it too do.
Thomas7740
Thomas7740
I really like the look of the newer Wacker Neuson but think I have more chance of bagging fog than finding a used ET58 are there any about ?
My bad, thought it was new you wanted 🤦‍♂️ no ET58, some et65s about but too heavy?
ET65 with tilty and buckets is going to be iro of 7.5t
Didnt want to go too big wagon wise - and get into the scenario of having to have a van as well - at the moment use my 7.5t wagon for everything running about wise.
You can push to just over 15t with mercs on the little running gear if you can find one
Failing that I don't know how replating works or is even possible in France but most wagons have a higher design weight so you might be able to squeeze a bit more in.
Also you could push it more further if you where to find a plate rather than a bin.
This 7.5t is what I run at moment ..... just going to go 12/14t same setup - there is diminishing returns as you get up in weight.
12t will carry just short of 6 with tipper body on.
14t around 7t
That 7.5t above has only got 3.8m back on it havent looked carefully at whats needed but will poss need to go 4.2m body to get back doors shut with 5.5t and tilty in 🤷‍♂️
14t around 7t
you need one of these if you can find one https://eurocomach.sampierana.com/en/sampierana-prodotto/65-tr/ .... or this https://eurocomach.sampierana.com/en/sampierana-prodotto/es-60-tr/
Bucket on wheels has had a fair bit of seat time in a Eurocomach with the VA and really rates them as a machine
or a taki with a VA boom like Gaz's ... but think his is too big ??
14t around 7t
Don’t forget you can load slewed with a king-post to shorten the bed.
you need one of these if you can find one https://eurocomach.sampierana.com/en/sampierana-prodotto/65-tr/ .... or this https://eurocomach.sampierana.com/en/sampierana-prodotto/es-60-tr/ View attachment 25533
They certainly look a decent machine on paper and we have a local dealer (not that you see much outside) but second hand like hens teeth and expensive.
yeh, but hear they're a sweet tool and you're on the right side of the ditch to find one ...... needle in a haystack over here :rolleyes::oops:
I think they are a fair bit dearer than other equivalent machines even accounting for extras like 2 piece boom (which eurocomach offer across a lot of their range). Tom Lomax did bring one or two into the country but I've never asked him why it didn't go any further.
last time I spoke with Tom earlier this year he was still an 'agent' ... but basically as said - very expensive - comparatively, but a very nice tool ... for an O/O they're a long term investment, but will stay the course and you have a seriously well made tool
I think Robustrack in Carnforth are the importers for them now.
