I’m also thinking we’ve a lot of nhl 3.5 line mortar to mix as well to rebuild the barn after concrete. 500 litre tracked pan mixer would be pretty cool
My concrete outfit run 6 Volis and 10 barrels, great when you want a bit of kerb mix then a c40 slab etc. 10m3 on big ones as well. My lads just taken a voli to st kilda for two weeks, long way from Buxton!There are more volumetrics round where I am than barrels by a long way
Even big pours have them running so can't be much difference in price
Rd us the voli lads will get where the barrels won’t, often farming lads who know there stuff. Similar terrain to lakes just not as highEverywhere is different i guess. I think part the problem for them round here was competing with existing setups and the fact that there's too many places they can't get to.
The only voli we had here were 8 wheelers so limited where they could go. There's even becoming less 6m3 barrels now, ok while there's lots of easy access big jobs on.Rd us the voli lads will get where the barrels won’t, often farming lads who know there stuff. Similar terrain to lakes just not as high
I like that..... pity it's in Scortlan'
Long way from anywhere by the looks of itMy concrete outfit run 6 Volis and 10 barrels, great when you want a bit of kerb mix then a c40 slab etc. 10m3 on big ones as well. My lads just taken a voli to st kilda for two weeks, long way from Buxton!
Think you can self load them to a certain degree![]()
Teagle Spiromix Mixer Concrete | eBay
Find many great new & used options and get the best deals for Teagle Spiromix Mixer Concrete at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
little un that Giles![]()
I’m also thinking we’ve a lot of nhl 3.5 line mortar to mix as well to rebuild the barn after concrete. 500 litre tracked pan mixer would be pretty cool![]()
Wouldn’t be able to mix line mortar in that though and probably too heavy to towA 1200 on a 3 tonne dumper would be even better
And being higher you could put a swivel chute like concrete lorrys so can run it out the side for foundations or kerbs
If you ever do concrete filled sandbags then pan mixers are so much quicker than a shovel and a road cone to fill them
Seen a Mycock barrel loose a decent part of its load going up through Knutsford last week..Rd us the voli lads will get where the barrels won’t, often farming lads who know there stuff. Similar terrain to lakes just not as high
Seen a Mycock barrel loose a decent part of its load going up through Knutsford last week..Fair play to the driver he had his brush out trying to clear it up, needed a sweeper - assume one followed up later.
15 miles or so about 30 mins awayWheres the nearest concrete plant, couldnt you just collect 1m3 at a time on your trailer then wet it up once on site ?
got a couple like that around here tooThat's rather energetic of him
Every steep hill round here has a line of concrete up the middle from overloaded barrels
