3CX bucket bushes
On the old 3CX buckets they have a hardened bush. Does anyone know the size of the hole in the bucket lugs that the bush knocks into?
Thanks
I thought the 3CX pins were 50 mm/ 2” so that would make the bucket hole size slightly bigger say 55mm!
1-3/4" pins (45's bloody close) and IIRC 52mm for the holes the spring / split bushes knock into .... I've got some new ones here .. 'll have a look tomorrow
Yep I’ll go with that a while since I knocked a set of them in, have a set kicking around in the lock up some where.
I used to just buy them from the main dealers, weren’t dear and always fit correct! I remember buying some pins once at 45mm.. and welding them into afew buckets what a nightmare!! We’re fine when the quick hitches had worn out abit as they fit snug then
Yep - 1-3/4" pins definitely. this works out to be 44.5mm, so a 45mm pin may fit in a worn bush (but not a new one)
My JCB Quickhitch uses the same bushes. The 'tit' (of the bush) that protrudes from the hitch measures 2-1/64"
I was basically trying to figure out if the 3CX bucket bush could be inserted into an 50mm quick hitch to get it to fit a 3CX pin setup. Seems it probably won’t be that easy....
I make that 51.2mm then ;)
could grind the outer down a bit James .... the outer isn't solid across the full width of the bushes ... 0.6mm off them, all round, wouldn't be too big an ask
T whiting
T whiting
You'll find that the pins are a lot further apart on a 3cx setup than on a 50mm bucket i know a 50mm gieth hitch won't slide far enough to pick up 3cx buckets
The 50mm Hill I mod.-ed for under the VA-r will pick 330 to 410 ctrs. Thomas ... all my 50mm buckets I had with the hitch off Mick are 400 and it'll pick up the Jake ones too on 45s ... all the same cheek spread at 165-170 mil. ;) Geith wanna get their act together :LOL::ROFLMAO:
Yes I have recently come across this with a geiaht bucket returning from site wrongly collected!
Geith have a range of hitches in each pin size, you can order about 6 different types with each one having about 150mm travel depending on the machine size
Thanks
right ... had a shufty for you ..
all dim.s are mil. ........hole size is 50mm as near as I can tell without knocking a bush out James ..... pins are 1-3/4" .... those dims are as it's sat on the bench .
by the time it's stuffed in a 50mm hole the bore will be 1-3/4" / 44.64mm ..... polish the outer off a bit James, 'fore knocking 'em in and you'd get a 45mm pin in 'em
