F
fred
they forgot the windows.
don't recall seeing it ... what's it worth?He was selling it here wasn't he to trade up
Was that your 3t kubota and engcon I saw for sale on facebook Fred ?
350h and S40 with gripper ??
I reckon that’s a sensible idea - I don’t think you want to go bigger than S40 on a 5 tonner personally.yes. not sure how it got on faceache though as I dont use it!
Im probably taking the engcon off to go on the 5 tonner though, im in no rush until the spring so leaving out there as there are so few clean, low hours 3 tonners about.
Maybe not hit. But deffo tapped...
How did you get on?
Good bloke in the truck'd have backed that in there ...... no sweat ....Nope, hit. Paint missing... I'm actually missing zero swing, never thought I'd say it. But I'll get used to it, and the stability is what I wanted really.
Wasn't really enough for the machine to get into it's stride. It's a bitch to operate when cold, and you really need the revs flat out for anything. The side console roller has fallen off. Tempted to make the mechanic come back to fix it, just needs to use threadlock this time. Bit s**t really.
The loadover height and crowd angle is really good. The bucket tucks right up - the boom will end up scratched over time but better than stuggling to load a Transit without spilling any. A lot of this could be down to the hitch geometry. I'm appreciating the hydraulic hitch already, but I think it has the same problem as the last- pin spacings too short, so it doesn't clamp up tight with even a little bit of wear in the pins. Why is Whites stuff so s**t? I'll make them come out and sort it like they did the E27, but it shouldn't still be happening. Last time you could see on the sliding jaw where the monkey that passed the welding exam had got it wrong once and cut it off before welding it wrong again- and I expect this one is the same. It's not rocket science- if the client specifies 125mm pin centres, then you make the sliding jaw top out at 127mm. Not 125mm.
But it did the job well enough. We knocked down a wall of the densest concrete blocks you can imagine, and the machine loaded them. Removed a load of old sleeper beds with the grab- good reach onto the truck for a small machine, and much easier than by hand. Built a couple of new beds- used the grab to pull the assembled oak frames around whilst we go the levels bob on. Then scratched out a pad, took a few loads away and then bastardised it drilling a couple of holes in the blade for a towball. One day I'll fill them in and make a nice removable socket and pin job to attach a towball. Mind you, I said that 5 years ago when I bought the Hyundai and drilled holes in the blade two weeks after it arrived. Never did.
Went and collected a shepherds hut from a few miles away with our beavertail and winch. Tight as a nuns arse getting her in, had hook the digger up on the road, shunt it through the entrance then take it off and reposition the digger, and finally jack the front of the tracks up on blocks to get enough drawbar height to unload. But you'd never have done it at all trying to reverse with a pickup. And to make matters more tricky the client wanted the towing A frame at the blind end, so this was the only option really.
Got to go and finish landscaping, install a cable and put a removable fence up where the wall was. I think the industry parlance is 'turnkey soloution'.... Anyway the profit on this two day job will have paid for the deposit on the new digger- I just need a few more of them.
It's amazing how you buy kit and then straight away find a use for it. I was sick of crap workshop jacks, so spend £150 on a 4 ton trolley jack a couple of weeks back. It was the bollocks for this job- we used it to get the hut up onto the two sets of ramps so it was wasy to load and again when siting it on the sleepers. The other thing that deserves a mention is the NivComp- must have saved two hours of messing around checking levels on this job alone, for the dig, the matched sleeper beds and the sleepers for the hut wheels. Got it from @Laser Levels Online two years ago and it's worth it's weight in gold for jobs like this.
How many hours a year do you expect it to do if its only done 60 hours since you got it?This is why i have a canopy! Easy two man job to remove. Second time it’s been off in the first sixty hours.
Nasty hard reinforced footings that weren’t expected have to come out- took the e10 initially but she was having a hard time of it soon as we found the footings. This is boss of the breaker, ripper and grab and really made a difference.
No idea, but it only costs me £285 a month on the drip so it doesn't need to do much!How many hours a year do you expect it to do if its only done 60 hours since you got it?
Can't put a price on convenience, having you're own machine to go to wherever and whenever you need it is hard to beat. Whether they are making you a fortune or just covering their costs doesn't matter.No idea, but it only costs me £285 a month on the drip so it doesn't need to do much!
Our workload and types vary. The E27 is up to 600 hours at 2 years old and the E10 350 hours at three years. But they all more than pay their way. The finance on all three is under a grand a month over five years.
The Hyundai it replaced did 1800 hours in four and a bit years, but now the workload is shared three ways (although we do more digger work overall)
The best money earned is the money the machine earns that hasn’t put an hour on the clock.
spot on ..... can never be over-equipped ...... when you have no idea what the next job will entailCan't put a price on convenience, having you're own machine to go to wherever and whenever you need it is hard to beat. Whether they are making you a fortune or just covering their costs doesn't matter.
Or over bucketed
I agree.very rarely I do more than an hour or two a day work on an eight hour dayThe best money earned is the money the machine earns that hasn’t put an hour on the clock.
