This was a three panel high wall from last year. I don’t think they can be beaten for value for money imo
TBF he could also go as one of the cast of a NCIS spin off
got a fizzog that looks like he just broke his tiltyTBF he could also go as one of the cast of a NCIS spin offView attachment 23169
To be fair even @Gunners doesn't talk enough sh*te to be in ncisTBF he could also go as one of the cast of a NCIS spin offView attachment 23169
Mog, you may have thought of this but thought I would say incase you havent. Whats the water table like where you are? When I'm doing pits like this (mainly for elevators) there is always at least 2 waterproof layers. The DPM is so prone to puncture I would want to make sure you have another decent layer of something, and maybe a drain around the outside to stop the water sitting around the pit walls?This is my attemptbuilding a pit in the workshop I’ll be building soon, dug the hole ‘nice clay
‘ and lined it with 1” thick steel plates to save any cave ins
unless I have the wrong end of the stick .... what's gonna stop the concrete rising and finding an equal level inside and outside the panels Mog? .. assume you want to do the walls and floor in one hit? looks to be a gap under the panels?This is my attemptbuilding a pit in the workshop I’ll be building soon, dug the hole ‘nice clay
then fabricated some steels that the panels slotted into and sat them on a vis queen membrane drop the panels in and Bobs your uncle
then to make sure it’s waterproof concrete around the outside in one pour![]()
Or are you planning to pour waterproof concrete?
Yes got two layers of dpm plus rubber conveyor matting down past the steelwork to prevent tearing it had the hole open since last Thursday couldn’t get concrete till today and was still dry in the bottomunless I have the wrong end of the stick .... what's gonna stop the concrete rising and finding an equal level inside and outside the panels Mog? .. assume you want to do the walls and floor in one hit? looks to be a gap under the panels?
Pretty dry on this yardWhat's the score with these and water pressure pushing them up. Bit like when they build inground pools in oz they have to do something with the drain before it's filled?
Its not the water pressure pushing them up, its gravity pulling them out of the ground. Those Australians are all upside down likeWhat's the score with these and water pressure pushing them up. Bit like when they build inground pools in oz they have to do something with the drain before it's filled?
That’s an in-ground safety deposit box - once his wallet is in it it won’t move anywhere...What's the score with these and water pressure pushing them up. Bit like when they build inground pools in oz they have to do something with the drain before it's filled?
yeh ......... put the plug in't hole or it'll take forever to fillWhat's the score with these and water pressure pushing them up. Bit like when they build inground pools in oz they have to do something with the drain before it's filled?
What no yellow rebar capsTook a picture this morning seems all goodat least no wild life fell in the hole and danced around all night
I'd be bloody amazed .....Pretty dry on this yardplus there will be a reinforced slab integrated into the top of it with 30+ cube of concrete then a building cast into the floor with even more concrete panels for walls
Will be very disappointed if it pops out of the ground
