European side of Ford has been ran from Germany for a long while. But taking it back to when they were more 'British' bil is restoring this for a lad he knows.Mine was a German built ford![]()
My staff cozzie was left hand drive and built in cologne GermanyEuropean side of Ford has been ran from Germany for a long while. But taking it back to when they were more 'British' bil is restoring this for a lad he knows.
Trying to weld em was fun for MOTs...few tacks+lots of sikaflex+ quick waft of rattle can...Used the bare minimum of tin foil to keep the mechanical bits in the right place
Like you say wouldn't wanna be in a big shunt in one but made for some fun motors.
Bil has a mk1 mex of his own he restored been done about 10 years now.My staff cozzie was left hand drive and built in cologne Germany
My dad's mex mk1 is being restored again since it's last one 25 years ago
you've obviously never had a mate cowering in the passenger foot well of a VitesseThings are looking up...come on lads since when were BL built rot boxes that handled like cruise liners fun? Poke![]()
so was my XR4x4i and the Scorpio that followed it when the XR got nicked and written offMine was a German built ford![]()
1300 auto shell by any chance? apparently they were also Köln vehicles too (and had a bigger tunnel, which was handy for building clubman cars)European side of Ford has been ran from Germany for a long while. But taking it back to when they were more 'British' bil is restoring this for a lad he knows.
That cars a 1300gt. Dunno about the bigger tunnel thing not my area but i know when he did his mex he had to put floors in it and when he went to put engine in starter cap was touching trans tunnel. Apparently the factory mod when they were built was to take a hammer to the trans tunnel and widen it but he'd already painted car so i think he modded starter cap instead1300 auto shell by any chance? apparently they were also Köln vehicles too (and had a bigger tunnel, which was handy for building clubman cars)
thanks Rob ... yeh that first one is close to the 'limit', but can't find anything closer to 50% over, than this un - significantly 'under-stressed' in comparison.Druid, I’ve had a look at the inverters you put the links on for
The first one will probably be ok for what you need. The thing to be careful about with those little inverters is that the components in them are right on the limit interns of capacity so I would advise buying a unit that is rated a good 50% over what you need.
Another thing to be aware of is never put a switch between the inverter and the motor. You must never run an inverter in to an open circuit.
I doubt you would have a problem with a drill but inverters have fans to cool them and they don’t like being filled with dust, particularly not electrically conductive grinding dust. Most inverters have terminals to connect remote buttons so you can put buttons on the machine and put the inverter out of harms way if you need to.
Hope this helps.
Rob
3 studsUsed the bare minimum of tin foil to keep the mechanical bits in the right place
You'll be starting on vanden plas nextyou've obviously never had a mate cowering in the passenger foot well of a Vitesse..... was plenty of room in the gap I got left with, to get a bus through ........ at well over the ton
....yes they were big, but handled well and I'd've rather been in that, than any of the tin foil hatches
yeh even the auto tunnels needed more space for a pinto motor's starter nose in the bell housing ..That cars a 1300gt. Dunno about the bigger tunnel thing not my area but i know when he did his mex he had to put floors in it and when he went to put engine in starter cap was touching trans tunnel. Apparently the factory mod when they were built was to take a hammer to the trans tunnel and widen it but he'd already painted car so i think he modded starter cap instead![]()
the V8SD1 VDP EFi,s didn't have the uprated spendies, that the Vitesses had ... 40mm lower, thicker struts up front, stiffer springs, bigger vented discs, slightly larger 4 pots, lowered rear springs and Boge rising rate adjustable dampers out back too. Oh plus a different diff ratio, uprated LT77 box and 15", wider wheels/tyres.3 studs
You'll be starting on vanden plas next![]()
1300gt and autos had the larger tunnel and the Mex had the starter on opposite side to the normal models due to having the 2000e box fittedThat cars a 1300gt. Dunno about the bigger tunnel thing not my area but i know when he did his mex he had to put floors in it and when he went to put engine in starter cap was touching trans tunnel. Apparently the factory mod when they were built was to take a hammer to the trans tunnel and widen it but he'd already painted car so i think he modded starter cap instead![]()
I'd completely forgotten about the stick hole juggle1300gt and autos had the larger tunnel and the Mex had the starter on opposite side to the normal models due to having the 2000e box fitted
If you wanted to put the type 9 5 speed box in anything other than the RS 2000 you had to do what druid said and hammer out the tunnel and also move the gear stick hole if you measure correctly you can cut it right lift the original hole up spin it around and weld it back in
My 1300xl mk1 was also an odd ball that it had a mk2 floor pan was a pain ordering parts for as I needed mk2 bits as mine was the last year of build
Any info on the solar panel bud ? Be good for the duck , it’s got a habit of draining down over a couple of weekskeep forgetting to say that @Rob65 's solar PV suggestion, as an answer to me P38's battery eating issues, seems to have done the trick.
Battery seems to be full of beans every time I've gotten in it, since lashing in a panel to keep yon battery topped up![]()
might get a few more ... Zetor'd benefit and JakieB, when I sort his breathing problems out ..... had a little endoscopey camera thing arrive yesterday (or was it /wed.s ??) to have a shufty in the inlets ...
swear there's a bit of nutshell in a valve seat somewhere and if I can sort it without pulling a head off I'll be much happier
So .. thanks to Rob for the PV answer to my problemand on the other advice front ..... reckon this'll suit me new drill Boyo?
1.5Kw 220V Single Phase/3-Phase Variable Frequency Drive Converter Motor VFD | eBay
Find many great new & used options and get the best deals for 1.5Kw 220V Single Phase/3-Phase Variable Frequency Drive Converter Motor VFD at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
