kubota kx36-3
macca
Hi all, I recently bought an Kubota kx36-3, the roll cage was detached and the owner had misplaced the bolts. I cannot find any info on the size I need to re-fit the roll cage, any knowledge out there, thanks
Probably metric, you just need a pair of verniers to find out the diameter.also buy a set of thread gauges, they’re pennies but save hours.
T whiting
T whiting
worst comes to worst load it up and take it to a bolt shop and see what fits.
Metric bolts are fairly course you can normally eyeball them off a tape measure just measure the outside of the thread
I remember the new ones need a small as well bolt or two for the handrail I don't know if it's the same on the older ones
Alot of kubotas have metric fine bolts... if the thread looks fine then they could be.
Stubota86
Stubota86
This is back right hand corner of canopy assume they are all the same
M14 x 1.5 would've been my guess exactly ..... the japs like M14, just to be awkward
Yes then put a smaller head (spanner size) on top just to confuse you🤔🤪
The french often have different sized heads on the nuts and bolts of a particular thread size, which I thought was ridiculous until it was explained that you only need one set of spanners to undo (ie a 12mm and a 13mm as opposed to 2x 13mm for example).
K
Keif
If a person doesn't have 2 x 13mm wrenches at a minimum, they ought not be wrenching.....🤣 Ill load of picture of my collection later.
Yes but a real pain if you are using a spanner and a socket and need to swap ends 😣
And who doesn't have a handful of 13mm spanners lying about 😆
British leyland 🤷‍♂️ landrover 🤷‍♂️
blast from the past .......................................... best left there :oops::ROFLMAO: ..... had a few in me time though :rolleyes::cry: .... and for a bit of controversy .... I really liked the original wedge ... had a few and found 'em a real comfy, tow barge. ........ and the land crab before 'em :giggle::giggle:
