Russell
I need a m8 and m10 tap. What is a good make of tap?
Just bought dormer duo kits this week comes with drill as well.I need a m8 and m10 tap. What is a good make of tap?
Dormer are good, I personally have some Volkel taps that seem good. Way better than the Clarke ones anyhow.I need a m8 and m10 tap. What is a good make of tap?
It worked thomake sure they're HSS .... high carbon are scheiser ..... presto are an equally good make ....... personally would not recommend driving a tap with an impact ..... recipe for disaster
I've always used Rocol ....Putting the tap in a drill-press is the easiest way to get it square - just don't turn it on.
Wind it in as far as you can by hand and you should be able to continue the cut on the same line.
This is the best lube I've found - makes a huge improvement over oil
CRC Trefolex Cutting Paste 500ml
Trefolex Cutting Paste is a green coloured, active cutting compound containing a colloid. It melts slowly as frictional heat is generated. It maintains efficient lubrication throughout operations such as pipe screwing, hack sawing, tapping and reaming. It is suitable for all users of hand tools...crcindustries.com.au
try M20It worked thoM14 takes elbow grease
but yeah not ideal.
depends on whether you're using a spiral machine tap or a hand tap ... spirals're designed to be 'driven'I've been using a battery drill myself. Is a bit scary but makes it easier to get it square.
I have some, broke a few, so don't really trust them now to be honest!![]()
HMT VersaDrive® Threading & Tapping up to 15x Faster than hand tapping
The HMT VersaDrive® Threading & Tapping range are made from exceptionally high-grade tool steel with ground flutes and titanium coating. The range is designed for long-life and high-strength, ready to tackle any challenge. Upgrade your toolbox today!holemaker-technology.com
ahar. knew I'd seen somewhere before, heard good things about this stuff.
from the horses mouth, usefull feedback as ever thanksI have some, broke a few, so don't really trust them now to be honest!
I have the drill/taps, and large ones, m12 m16 etc. they dowork, but as always when you break a tap its in the worst posable place at the worst posable time!from the horses mouth, usefull feedback as ever thanks![]()
Arrgh yes, law of sod.I have the drill/taps, and large ones, m12 m16 etc. they dowork, but as always when you break a tap its in the worst posable place at the worst posable time!![]()
We got a load of their taps to try out but little success, have all but given up on them apart from the rota broaches, they work well. We now get taps fro cutwelI have some, broke a few, so don't really trust them now to be honest!
have to admit to thinking the same too @pettsy ...... only a hydraulic versionBeing a plumber, the thread wasn’t quite what I was expecting![]()
Just dragging this back to the top- this s**t is incredible. As soon as you add it to the drill tip, the swarf starts spiralling off. It's like night and day. Witchcraft, I tell thee!I've always used Rocol ....
Rocol takes some beating as a cutting compound Doob ... as said - witchcraftJust dragging this back to the top- this s**t is incredible. As soon as you add it to the drill tip, the swarf starts spiralling off. It's like night and day. Witchcraft, I tell thee!
