What make of tap?
Russell
I need a m8 and m10 tap. What is a good make of tap?
Just bought dormer duo kits this week comes with drill as well.
I stick with Dormers prob getting my pants taken down but they work.
Got an M14 and trying to figure best way to run it from my impact Wrench...done two Taps in 10mm plate and buggered the bodged socket but worked very well.
make sure they're HSS .... high carbon are scheiser ..... presto are an equally good make ....... personally would not recommend driving a tap with an impact ..... recipe for disaster
It worked tho🙄 M14 takes elbow grease😂 but yeah not ideal.
Putting the tap in a drill-press is the easiest way to get it square - just don't turn it on.
Wind it in as far as you can by hand and you should be able to continue the cut on the same line.
This is the best lube I've found - makes a huge improvement over oil
I've always used Rocol ....
try M20 :LOL:
now these need elbow grease LL :p:LOL:
ahar. knew I'd seen somewhere before, heard good things about this stuff.
I have some, broke a few, so don't really trust them now to be honest!
I have the drill/taps, and large ones, m12 m16 etc. they dowork, but as always when you break a tap its in the worst posable place at the worst posable time!:rolleyes:
Arrgh yes, law of sod.
We got a load of their taps to try out but little success, have all but given up on them apart from the rota broaches, they work well. We now get taps fro cutwel
two things to remember when machine tapping ....... the tapping hole HAS to be to spec. -- end of -- and ideally drive the tap through a tapping head, which has auto reverse when/ before it encounters resistance great enough to bust the tap
going at it gung ho with yer cordless Dack and Blecker is not what they were designed for :rolleyes::(:mad: machine taps are designed to be used in machines .... hand taps're for use by hand
Just dragging this back to the top- this s**t is incredible. As soon as you add it to the drill tip, the swarf starts spiralling off. It's like night and day. Witchcraft, I tell thee!
Rocol takes some beating as a cutting compound Doob ... as said - witchcraft :ROFLMAO:
