Ifor Williams trailer work lights
I’ve ordered for feb delivery an ifor Williams tiping trailer,
has anyone fitted work lights to them namely extra reverse and some work lights on ladder rack.
It has a battery and remote tip etc can run straight from that and use the charge while towing function I think but was wondering about powering them directly from the euro connector.
ordered some durite lights rather than the Chinese led ones
also any tracker recommendations for it as theyre like the most stolen tings lol
T whiting
T whiting
I'd just take a feed from the battery then you can use the lights if you leave the trailer somewhere.
Have you seen the remote tip setup that James covel has fitted to his it would be worth having as they are painfully slow coming down the last 3 ft when empty
Depending what your towing it with a new ifor will have 13pin connection and a junction box under the bed so adding extra lights on the reverse circuit would be easy
Yeah says in there I’ve ordered remote tip, it’s only £79 option. I’ve had nearly every option apart from solid sides Had mesh on the 12x6
Nothing wrong with Chinese LEDs in my book
I’ve got a few failing ones on my kubotas where say 4 of the 8 leds have gone, or they’re full of water they aren’t ip67 etc. I’ve got plenty of Chinese light bars on dumpers etc but when you do compare to say the Stedi lightbar on my amarok there is a difference in quality
T whiting
T whiting
So it does teaches me to learn to read 🤓🤓
Did you go for in bed lashing eyes? We were advised against them as they hold the muck on a tipper
Cyberprog
Cyberprog
I'd have them relay operated. When vehicle power is provided their +ve feed would come from vehicle, when removed it would be battery. Then a second relay to go from a manual on/off work light switch which is over-ridden when reversing.
So if backing up, they will be on from the vehicle.
If the trailer is connected to the vehicle, the lights will be powered from the vehicle if you toggle them on.
Finally if no vehicle, you can toggle them on/off with the switch too.
Maybe throw a VSR in there for battery protection too.
Cyberprog
Cyberprog
I've got loads of Chinese LED units. Cheap and plentiful, never had any issues.
and a massive difference in price though ... could get through a few chinkies before you match 'em
48w Chinese ones are a fiver a go. Had some on vehicles five years with no probs.
Stubota86
Stubota86
I’ve been thinking about something similar probably wire a load of work lights to come on with reverse lights with a simple switch on the trailer so can isolate them for when you’re reversing next to traffic etc.
I rewired a trailer recently - the Ifor wiring centre is nice to install:
Automatrics seem to be popular trackers, not too expensive either
Wire a couple of led work lights off the trailer side lights through a switch. If you're reversing at dark one of the most off putting things is glare from the tow vehicle reverse lights off the front of the trailer and the trailer front marker lights (neither of which I've ever done anything about yet).
Justme
On my car when towing & reversing it does not turn cars reverse light on, only trailers.
Same with fog light only trailer one comes on.
