There you go.... Print it off, and tell em to roll it in a ball and shove it up there Arse.
Handy that as it's one of the hitches (on smaller machines) that i don't actually is the strongest built for reverse buckets. Never broke mine yet mind.View attachment 19619
Sorry Rory, I'm going to disagree with you here. (I acknowledge that I have trimmed the piece above, but hopefully not in a way that changes the message or context of what you have written)Use Of Reversed Buckets and Forks in Excavator Operations
Foreword:
The following text is information gleaned from 10 years’ actual practical working experience and the knowledge gained as such. This information is not infallible and if doubts or concerns are seen you should consult the machine manufacturer for information – RJS-2020.
Risk Of Detachment:
Direct Pin - The simple reality is the only heightened risk posed by reversed buckets in most operations is due to bucket detachment. This risk is NOT INCREASED on excavators with Direct Pin Mounted Buckets.
The Semi Q/H - or Safety Pin Hitch has mostly been disowned by most of the industry. Whilst the design of the hitch is inherently safe (A Safety Pin MUST be inserted for correct operation, which Mechanically locks the Hydraulic/Spring Loaded Jaw Shut) If Used Correctly The Pin would Prevent the Jaw being pushed into the open position by use of a reversed Bucket and therefore the risk is NOT INCREASED by use of a reversed bucket
Fully Hydraulic Q/H – These Hitches Rely on Full Hydraulic Pressure to open and close the hitch and mostly have a front locking Jaw that functions on both the full retraction of the ram And/Or Gravity/Position of the Hitch. These Hitches theoretically could be forced open by pushing the rear jaw back however it’s exceptionally unlikely this would happen as it’s unlikely the reduced forces of the arm would generate enough power to do so. And even if they did it’s doubtful the front lock (Twin Lock) would raise to allow full bucket detachment. Put short the risk is NOT INCREASED
S Type Q/H
these hitch systems are Different from the Standard Pin Grabbing Systems (See Above) In that they use a calibrated system of pins suited to the various sizes. (S30, S45, S60 Etc).
The Danger with these systems is many are not Twin lock and rely on the Hydraulic pressure and Electro Hydraulic Interlocks to prevent detachment. Theoretically force could be applied that would force the rams open and create a dangerous situation. However reality is very different and these systems are considered very safe in the country’s they are used (Scandinavia). Most S Type Hitches are on Tilt Rotator Systems which eliminate the bucket reversal argument anyway.
Use of Forks on Excavators:
The use of Forks and other load carrying attachments (Pipe Handlers, Block Grabs, Kerb Grabs) Requires simple thought and a person capable of reading a load chart.
Attachments that hang from a chain can be utilised simply as the load centre will correspond to the chart.
Where Forks or Similar are used which extend the load centre out a competent operator should be able to interpret the chart and gain the correct SWL by looking at the Distance from slew ring, and working out the load centres position relative to the charts corresponding points.
It is worth considering the fact that Tracked 360’ Excavators are not ideal for fork operations as there machine design makes them prone to jerky movements on uneven ground. HOWEVER in certain circumstances they can be far safer than a telehandler or traditional rough terrain masted forklift as they can sometimes pick and place loads without directional movement and are often more stable on sloping or soft ground.
No disrespect intended Robert, but the ram argument doesn't stand up for me. I'm quite certain that the amount of force that could be applied to a reversed bucket is far less than would be required to force the ram shut as the ram forces involved are on the weak side of the ram.Sorry Rory, I'm going to disagree with you here. (I acknowledge that I have trimmed the piece above, but hopefully not in a way that changes the message or context of what you have written)
Where the (reversed) bucket is directly pinned to the dipper then you are quite correct in saying that the risk of detatchment is not increased, but (leaving aside the semi-automatic hitches which you shouldn't see on sites these days),reversing the bucket on a pin-grab type hitch is not good for the following reason: When you are using a bucket in the conventional sense, the pirmary digging forces are on the hitch jaw closest to the digger, which is a fixed (and usually cast) item designed to take the maximum breakout force associated with that digger. If you reverse the bucket, the forces are now on the hitch ram and this is not what it was designed to do. For completeness, a semi hitch safety pin is designed, amongst other things, to hold the hitch closed against accidental operation of the hitch mechanism, not against the increased forces on the hitch ram which is now having to counter the bucket ram forces. Compare the size of the hitch ram to the bucket ram and I know which one my money's on.
Similarly, your point about S-type hitches is not fully developed. FIrstly, the S-standard is most closely associated with tiltrotators and they do not suffer the same problem I outlined in the paragraph above because they rotate the hitch with the bucket so that the open/shark jaw is aways facing the same way as the open face of the bucket. For this reason, when used underneath a tiltrotator, there is no 'bucket reversal'. You also make a point about some S-type hitches being 'not twin lock'. Let me at this stage make the point that, from a worldwide perspective, virtually all S-type hitches are not twin lock. Twin lock hitches are a UK phenomenum and are, IHMO, a fundamentally dangerous development, not from what they are designed to prevent, but what they allow an operator to do:
To divert; a twin lock device is designed to prevent the bucket or other attachment from detaching in the event that the second axle is not properly engaged by the pin grab, or if the hitch ram fails for some reason. The bucket will swing free, but not detach because the twin lock mechanism has grabbed the pin nearest the cab. A good thing, until you observe what a lot of operators do, which is use this feature to move buckets around site (usually at the end of a shift when they are tired) without fully picking them up with both axles. Not only is this bad practice, but it also can accelerate degradation of the twin lock mechanism. S-type hitch manufacturers (with one exception) have adapted their hitches for the UK market by fitting twin locks to sell their hitches, not because it's a good thing. They've done it because some main contractors will not allow non-twin lock hitches on their sites. I've had this discussion with a number of them over the years and they start by saying that they do it because 'it's the regulations'. Not true. There are currently two relevant regulations in play here: one European and one UK (HSE). The first is that the Operator must have read, understand and fully comply with the hitch manufacturer's operating instructions. The second is that the hitch must be so constructed that, in the event of a loss of hydraulic of other excavator power, the hitch must not be capable of allowing the attachment to become detached. That's it - there's nothing about twin lock in there.
It follows that if you reverse a bucket and use it as a face shovel, not only do you run the risk of degrading the hitch ram, but you also run the risk of doing the same to the twin lock mechanism.
You may extrapolate these arguments for the use of forks on an excavator. Clearly, unless you want to risk puncturing yourself whilst sitting in the cab, the best solution is to have the forks facing away from you. However, for the reasons above, doing this is going to put an amount of stress on the hitch ram that it was clearly not designed for. For this reason, the use of load tables with forks on an excavator needs to be very carefully read and, with reversed forks, I would argue cannot be applied. A fork manufacturer will give a calibrated figure (in my direct experience a TP(500) number in tonnes) which corresponds to the load capacity of the forks themselves. This needs then to be interpreted alongside the excavator load charts to give a safe load envelop for what's being picked up. I've yet to see any figures attributed to the (pin grab) hitch ram in this regard and, TBH, I wouldn't stand within a country mile of any digger operating a set of forks like this.
As will come as no surprise to any of you that know me, these are some of the arguments for investing in a tiltrotator, and a powerful secondary argument for the low build height of the S-type hitch.
All, as ever, IMHO
Robert
No disrespect taken at all RoryNo disrespect intended Robert, but the ram argument doesn't stand up for me. I'm quite certain that the amount of force that could be applied to a reversed bucket is far less than would be required to force the ram shut as the ram forces involved are on the weak side of the ram.
Shhhh youI guess another thing to note re tiltys and hitch always being the correct way round is that many will be direct mounted but possibly a UK thing is top hitches which would then load the hitch the other way round.
and have far greater leverage than without the tiltyI guess another thing to note re tiltys and hitch always being the correct way round is that many will be direct mounted but possibly a UK thing is top hitches which would then load the hitch the other way round.
That's it, pour the propellant on the fireI guess another thing to note re tiltys and hitch always being the correct way round is that many will be direct mounted but possibly a UK thing is top hitches which would then load the hitch the other way round.
Only way to stop it smokingThat's it, pour the propellant on the fire![]()
No disrespect taken at all Rorybut I'm still going to disagree with you.
The reason there is a weak and a strong side to the ram (and a fast and a slow side, too) is because the cross sectional area (CSA) of the strong side is greater because it doesn't have the piston rod. For this reason the (excavator) oil pressure is working against a larger area and can produce a greater ram force. My argument is that the effetive CSA of the weak side of the bucket ram is still larger than the strong side of the hitch ram (these things are tiny in comparison) and, as such could be overwhelmed.
I take your point on the other matters
I probably haven't explained it very well, but there a bit here https://learnoilhydraulics.com/page...r-in-one-direction-and-faster-in-the-opposite that goes into more detail.
Robert
And the fact that on a JCB 220x LR the bucket ram retract stroke will be around 3/4" and the hill q/h ram is around 3" bore.....Yes but you need to take leverage into account.
Agreed, Doob. Someone mentioned earlier that Hill, who do not make a bad product, have certified (one of?) their hitches for reverse functionality such as a face shovelling. For the avoidance of doubt, the comments I made earlier were directed at general pin-grab type arrangements which are just designed for normal operation. If you have the relevant Hill hitch (or one from another reputable manufacturer) that is certified for use in this way then clearly my comments do not apply.Yes but you need to take leverage into account.
Your welcomehas managed to get my head above the parapet on LinkedIn (cheers - I owe you for that............)
Allow me to explain what happens with safety innovations IMHOThe moral of this is that it is damn difficult to innovate in the UK construction industry and the default (usually driven by large site operators) is to close down what is not accepted (for whatever reason) by them as the 'norm'.
..........that'll test the QH/forks theories... but with the safety pin in, you'd have to gas it out
Welcome to the UK, is all i can say.Your welcomefor the record it was either tag you or Taylor and I thought you would defend it best. Not out of spite or humor at all.
One Of Proturpin's engineers designs a totally unnecessary "safety Innovation... a salesman then sells this in bulk at a discount to a big contractor such as Flannels Plant.
Now the stage has been set, Flannels Rep sells the totally unnecessary device to a Main contractor such as Betty Bullfor on the premise that it will make there sites safer. They then Insist on that item being Mandatory..... which suits Flannels and Proturpin and fucks everyone else in the arse..... (Just my personal opinion).
What is positive for H&S innovation fucks everything else tho.
Selector grab should be added to list with forks and bucket reversed
First time I heard of Eddie on here..what's he up to these days? Sorry I don't do FB.Tree shears should be and what about fly jibs like lpgeddie has on his liebherr
But as I said before if the rear jaw is sliding type then forcing the ram is irrelevant as the quick hitch ram moves in a different direction to the force being applied
It's only if the rear jaw is a hinge that it could theoretically loose grip
neither does heFirst time I heard of Eddie on here..what's he up to these days? Sorry I don't do FB.
