windy gun and long extension bar ? .. ideally a 3/4" bar so you don't lose the impacts in the spring of a 1/2" extension ... if you have to use a 1/2", pretension it with a stilsons, before pressing the trigger .. two hand-er really for thatI’m removing the upper from the ring, once done the plan is to completely move the upper and undercarriage away from each other and then remove ring from undercarriage with plenty of room. The slew drive problem is acces to get enough leverage. There isn’t much room in there
