Kobelco SK135SR ROM DATA FAILURE
3
3cpowertrain
Hi got a kobelco SK135SR and we have several faults showing and she won’t rev up or shut off on the key.. main fault is ROM DATA FAILURE.. can anyone advise repair.. I’m thinking computer faults..
Two options, Proper repair, or Cable Control/Stop.
Proper repair is electrical engineer and some coin, I expect it's a corroded electrical plug somewhere but could be £££'s,
Other option would be to run a cable throttle and cable stop control.
three options Rory ..... see above ;):oops:
3cpowertrain
Morning funny you say that just done similar on an old JS130 tracked it back to a failed computer / throttle controller and put a throttle cable assembly on it not ideal but got it going..
Try disconnecting the alternator, had that on a machine once, alternator was faulty and back feeding the ignition system and this was causing some strange faults!
Might be a long shot, but will cost nothing to try it.
mart1602
you can send the ecu off to be checked ,d king agri electronics will do them
good call ... I've had a faulty alternator/regulator throw up all sorts of weird issues on kit before now too .... and'd never credit it to that
G
Goodwin
Hi how’d you repair it pal I’ve got one doing the exact same thing
