Dumpers, hydrostatic drive the best?
@Storrsy I had exactly the same requirements as you, kept hiring a 3 ton but they are a bit big, 1t just too small. Back in March I purchased a new Thwaites 1.5t hydrostatic swivel and its been great. So much more productive than the 1t whilst still being able to go behind the digger. Really glad I bought it now. Thwaites do a 2t hydrostatic but you don't want to know the price. At the time I was buying mine, I went through all the prices on here (think its in my Gunns Contractors thread) I had for each spec, manual, hydrostatic etc so should still be fairly current now I'd have thought. I also reviewed it on my youtube channel (cheeky plug!) www.youtube.com/olliegunns
Those Wacker Neuson dumpers are really well made but I find them hard to get on and off as the steering column is quite big and the step is pathetic. I like the fuel gauge on the dash though and the paintwork is superior to the Thwaites over the long term. Both decent machines really with strong residuals
Great video on that dumper 👍. I hadn’t really considered the Thwaites simply as I wasn’t thinking about buying new and as you say hens teeth in the used market. Did get a price for a 2 ton Wacker today which was £20k+ vat. I can’t justify that on a dumper really, plus I’m really starting to think that the 1.5t hits a sweet spot, even 2 ton is going to be a little wide on some paths I work on. Couldn’t agree more about real world dumper capacities either- I don’t think I’ve ever managed to actually fit a ton in a 1 ton dumper!
Hg2702
Hg2702
the Thwaites fitted snugly on my 9x5 trailer I mean literally an inch either side ( I think the trailer is 9x5)
still a nice bit of kit and easy to load with the 216 definitely be using one more often than a 3 as it just keeps things moving if that makes sense
Regy53
Regy53
I like cake
Get a terex ta2seh ! Il quote you one if you like 1498 mm wide btw residual value through the roof
Are terex smaller ones still a joystick and hand throttle setup.
Not anymore, and haven't been for some time now. I find the Terex (now Mecalac) stuff performs well but there's strange quirks I don't get on with on them. The shape of their swivel skips is foremost in that list!
Left hooker
Left hooker
Find manual and shuttle gear box dumpers climb piles better than hydro ones
Also jcb 3cx has torque lock so it's direct drive must be a reason it's better with proper drive
Hydro drive seems to be jumpy when the going gets tough wheras shuttle/gearbox dumpers are a lot smoother which is why i think they grip better.
my Thwaites climbs like Sherpa Tensing .. now't stops it, 'cept maybe the pilot's balls ...... went up there full to the brim and would've gone over the top, but - (see pilot comment :giggle: )
four on the floor and two on the column
I dont' know if it would suit your work, but you could also consider a small tracked dumper? I have a 1.8t Yamaguchi, only downside is it might be a little too wide at 1.6m
Open to anything at the moment.
Is that the Yagamuchi WB18B? If so I think it’s only 1330mm wide Which would be perfect and at 1200kg it’s pretty convenient to tow around.
What kind of money are they new?
Cheers
Cheers
Plus if I ever got bored of it as a dumper I’ve always fancied making a mini tracked post driver.
