Rob 210
you need to crank up the volume to appreciate this singing scammel
No mate I didn't film it.There are several vids of the old girl on the tube.that one is a bit tame to a couple of them! There's just something about those Motown 2strokes, soundsDid you film that? It sounds like whoever did maybe liked it a bit too much!....
a mate had a bedford 6 wheeler roll on skip truck that had a detroit 2 stroke in it i think a v6 his sometimes would start in wrong direction if he nearly stalled it or similar black smoke would fill the cab etc it had some sort of flap on engine inlet to be able to stop it if engine ran away. he thought it was not powerfull enough when it was up to its max weight and soon sold it on, think for export.used to have three cranes running Cummins V8s ... a 504 in a Grove TMS180 and two 555s in a Coles 25/28 and an 825 Supertruck .... twin stacks ... virtually straight throughs ..... sounded absolutely glorious .... whichever way out of my old yard was an uphill pull, but gentle enough to 'make progress' up the box![]()
mate had a CZ 350 or 400 (?) 'crosser which was timed so close to TDC it was luck of the draw which way it ran ... would very often take off back'ardsa mate had a bedford 6 wheeler roll on skip truck that had a detroit 2 stroke in it i think a v6 his sometimes would start in wrong direction if he nearly stalled it or similar black smoke would fill the cab etc it had some sort of flap on engine inlet to be able to stop it if engine ran away. he thought it was not powerfull enough when it was up to its max weight and soon sold it on, think for export.
Sounds like Francis Bourgeois!Did you film that? It sounds like whoever did maybe liked it a bit too much!....
that's got to have had a Cummins heart transplant![]()
1.6M views · 33K reactions | The REO’s getting some miles put on her 🇺🇸🚛💨 #army #military #americanmade #bigturbo #diesel #fypシ゚viralシ #fypシ゚ #fypviralシ | R Commercials
The REO’s getting some miles put on her 🇺🇸🚛💨 #army #military #americanmade #bigturbo #diesel #fypシ゚viralシ #fypシ゚ #fypviralシwww.facebook.com
No, that's how they sound as standard, my Dad has one that he goes to shows in.that's got to have had a Cummins heart transplant![]()
beautiful sound trackNo, that's how they sound as standard, my Dad has one that he goes to shows in.
They are a multifuel engine, primarily to run on diesel, but in combat uses can run on pretty much any fuel, petrol kero, jet, or oils as along as it has a bit of diesel/oil mixed with it. On the pump there is a fuel density measuring device that adjusts the fueling to suit the fuel used at the time.
They are built straight piped from new.
