's got one ... same as mine ...... big blueBe alot more useable with a roof
It’s being delivered on Wednesday apparently! Can’t go on until Scottish Power do their bit though...Be alot more useable with a roof
It’s going to be my giraffe enclosure - leave the power lines in place to act as an electric fence so they don’t eat all the trees.Yes but can get tall stuff in![]()
gonna need some tall employees .......... come milking timeIt’s going to be my giraffe enclosure - leave the power lines in place to act as an electric fence so they don’t eat all the trees.
The guys who laid it said that the concrete was really good (Breedons - they sourced it, I had no involvement in any of it). They’ve had issues with other suppliers before on bigger pours when the job is located centrally so that the trucks come from different batching plants, and everything goes off at different rates.My new shed floor took 4 days to polish up! The Last load went off fine in under 8hrs.. all the others were a right bugger up!!
It’s Covered in mud now![]()
There won’t be much change out of £60k by the time it’s all done and wired up (which is about £20k more than I had in mind when I started thinking about it but I’ve upped the spec every time a decision has needed to be made!). It ‘should’ be worth more than that/add more than that onto my property value though I hope, and it’ll be amazing to have somewhere dry to work on kit at home!What do you think it will stand you at by the time it's clad and got a lot on @Monkeybusiness
It does look the dogs!
How did you get it through planning?There won’t be much change out of £60k by the time it’s all done and wired up (which is about £20k more than I had in mind when I started thinking about it but I’ve upped the spec every time a decision has needed to be made!). It ‘should’ be worth more than that/add more than that onto my property value though I hope, and it’ll be amazing to have somewhere dry to work on kit at home!
It’s a tractor shed/dry feed store as I’m a farmer with a flock of sheep. I ticked enough boxes to get it through permitted development...How did you get it through planning?
Which reminds me that I need to get on with mine before time is up!!It’s a tractor shed/dry feed store as I’m a farmer with a flock of sheep. I ticked enough boxes to get it through permitted development...
