Tiltrotator build
HeliPilot
HeliPilot
Hi All
I recently exchange my old mini digger to do some work around our small farm.
Been working on putting a tilty on it.
Looking forward to continuing watching all your great comments..!
Where abouts in Surrey? Let's see some pics, whats the mini and tilty?
Welcome to the forum. Not far from that part of the world myself. What kind of work do you do?
welcome Boyo ... only bits of Surrey i know reasonably well are around Hindhead/Haslemere/Hogs Back sort of areas ... used to be a nice part of the world .. dare sat it's changed ..... a lot !!
Hindhead is a bit nicer since they built the tunnel under it for the A3.
Jimoz
That devils valley walk above the tunnel in hindhead nice got some friends live a few mins away
HeliPilot
HeliPilot
Kenley near the airfield
Kenley near the old airfield
Im currently still building the tilty, just tested the rotator all seems ok with plenty of speed
HeliPilot
HeliPilot
Hi there V8 I think we may have spoke before...?
HeliPilot
HeliPilot
Its in my back garden at the moment pulling out some sizeable tree stumps Its a 100hr 8026.
ask 'em to take you down to Wagoner's Wells next time Jim
take it you've 'gutted out' that chinky rotator for the bits?
yeh .. if you're who i think you are ... hence the above comment ;):) ... assume you considered the original body too much of a faff to fit to, or not substantial enough ?
HeliPilot
HeliPilot
Ive used the gear from another one and then built the new enclosure from steel. I was concerned about welding to the original cast enclosure.
Still got the complete larger one
you obviously have access to some nice machining facilities ... you lucky chap :sick:
think those chinky jobbies are cast steel though aren't they ?? not black iron
HeliPilot
HeliPilot
They've told me they are iron but I do suspect they are cast steel, I'm not a welder so not tried to weld it.
I did notice the guy on youtube attempting to weld an Engcon and that is cast steel and he didn't have much luck with it..
HeliPilot
HeliPilot
I do have a question about how to run the hydraulics, should I post here or start a new thread?
This thread is good mate, it's not strict here. Threads derail totally all the time, so by our standards a question about the hydraulics would be very much on topic :ROFLMAO:
HeliPilot
HeliPilot
Ok so here goes. My hydraulic knowledge is very limited and my terminology will most likely be way off..:confused:
I currently have one proportional aux control via foot pedal or right joystick. (A push button on the left stick changes from one to the other)
For the tilt rotator my plan is to mount a couple of proportional valves on a two station manifold to the tilty and supply the manifold via the current aux circuit.
I have installed a roller button to the left joystick which will control the rotate prop valve, and the right roller will control tilt prop valve. A switch/controller will disable the current right roller function (Aux) to enable use for tilt function only.
My question is what would be the best way to supply fluid to the manifold? (I have assumed this needs to be constant from P to T)
Regy53
Regy53
I like cake
I would suggest starting a new thread. I can move the posts across, reason being is more people may look at it rather than a introduction post. means you may find more info etc Completely up to you
I have moved the whole thread and changed it to tiltrotator build. I am happy to change it back if you wish, or change the tittle to whatever you like. Looks like some skill you have
