Steve
I did think they would be a lot more vulnerable.With a hydraulic hitch on a small machine, do the pipes regularly break due to all the tight radius bends they have to make.
Nick...
Nick...
They are the most likely hoses to have a problem with on the machine but it's more to do with the fact they are right in the end of the arm. You do have to be more aware especially on smaller machines if you digging among roots or moving a lot of branches etc. I rarely have any bother but if i was speccing a 1.5 tonner purely for hiring out on self drive no way would i put a hydraulic hitch on.With a hydraulic hitch on a small machine, do the pipes regularly break due to all the tight radius bends they have to make.
Nick...
The hose routing on my 2.8t is quite tucked away, kind of inside the tipping links. Have ordered hydraulic hitch for my new 1.9t also.They are the most likely hoses to have a problem with on the machine but it's more to do with the fact they are right in the end of the arm. You do have to be more aware especially on smaller machines if you digging among roots or moving a lot of branches etc. I rarely have any bother but if i was speccing a 1.5 tonner purely for hiring out on self drive no way would i put a hydraulic hitch on.
Mine are tucked away ok as well, not as good on the 1.9 ton. Ironically best tucked away is on 4 tonner and that's the only one I've had bother with. Stone got in on top of hitch digging deep trench and i didn't realise until i heard the crunch when emptying bucketThe hose routing on my 2.8t is quite tucked away, kind of inside the tipping links. Have ordered hydraulic hitch for my new 1.9t also.
Get good with the bar..... change a 1.5t bucket in under a minute if you get good![]()
