No work today but plenty to get on with at home so a day putting firewood away for later in the year it was.
Plenty gear on the job makes life easy.
I'm glad that it's not only me that does productive stuff like thisNo work today but plenty to get on with at home so a day putting firewood away for later in the year it was. View attachment 13468View attachment 13469View attachment 13470Plenty gear on the job makes life easy.
Yep first saw it used by someone on a 3c years ago - never done it myself but agree that getting your machine sat level helps a lotSo the in thing at the moment being levels idig guidance etc thought I'd show something i use a lot and don't know why manufacturers don't fit it. View attachment 13528Maybe others have the same idea but my old fella was old school op and the one thing he always instilled into me with any machine was that a lot of you're feel is through you're arse. Not only that but even with tiltys idig etc there's still no substitute for sitting a digger in the right place. If you want to dig flat and level sit ur machine level. If you're not on a huge area its surprising how near to right i can bulk a level flat area without even getting laser out the box. Takeuchi used to have a flat spot along bottom of front window you could sit a 600mm level on that aligned perfect with grading bucket for level. Unfortunately newer taks don't but above works the window works ok.
Only by those who hadn't thought of it.Mate, you should have seen the flak I got on the old forum for using a level....
Great idea - been using a 'brick level' taped to the waist high bar of my cab for about 5 years or so nowSo the in thing at the moment being levels idig guidance etc thought I'd show something i use a lot and don't know why manufacturers don't fit it. View attachment 13528Maybe others have the same idea but my old fella was old school op and the one thing he always instilled into me with any machine was that a lot of you're feel is through you're arse. Not only that but even with tiltys idig etc there's still no substitute for sitting a digger in the right place. If you want to dig flat and level sit ur machine level. If you're not on a huge area its surprising how near to right i can bulk a level flat area without even getting laser out the box. Takeuchi used to have a flat spot along bottom of front window you could sit a 600mm level on that aligned perfect with grading bucket for level. Unfortunately newer taks don't but above works the window works ok.
Shame it can’t level the picture upSo the in thing at the moment being levels idig guidance etc thought I'd show something i use a lot and don't know why manufacturers don't fit it. View attachment 13528Maybe others have the same idea but my old fella was old school op and the one thing he always instilled into me with any machine was that a lot of you're feel is through you're arse. Not only that but even with tiltys idig etc there's still no substitute for sitting a digger in the right place. If you want to dig flat and level sit ur machine level. If you're not on a huge area its surprising how near to right i can bulk a level flat area without even getting laser out the box. Takeuchi used to have a flat spot along bottom of front window you could sit a 600mm level on that aligned perfect with grading bucket for level. Unfortunately newer taks don't but above works the window works ok.
Yeah do try to if it's a few inch thick it's easy enough and even if you can't keep it clean you can always lose it in there deeper bits when you backfill. End of the day the time saved out weighs lost stone.Do you bother trying to save the stone ontop of the trench?
One from a while back old bungalow was demolished by someone else (was mainly wood and left a complete tip behind) levels were to build up a bit and some rubble to lose on site. Rubble was lost under where patio was to go then 100 ton subbase in to raise level up to near enough floor height. Lot easier grading a rolling that quantity with 7.5 tonner and bomag 120 than doing it when walls are in way. Then dig through for founds. Always like to hardcore sites as soon as possible we don't have lakes up here for no reason. View attachment 13663View attachment 13664View attachment 13665
Then back at dpc to fill round. Also got all services and drains sorted at this point which is rare but due to the fact there had been a bungalow here before they were all on site so were redirected and connected. View attachment 13666View attachment 13667
Tidy work and a tidy site. Good job!![]()
thought of this as I climbed out the 'Drema today ......my favored weapon ....
got one down beside me seat in the 'Drema on a nice solid lump which is perfectly aligned with me slew ring... get yerself level in all directions and where-ever you spin round to, yer's level
...... used to drop one on the top of the kingpost swivel on the jake ... all very well being level cross chassis, but also need to be level fore to aft or when you come off centre, you're all to cock
had them fitted to me cranes ... need to be 'proper level' with 100 odd feet of stick in the air![]()
