T whiting
Has anyone got any recommendations for retrofit imobilisers for plant. I'd like something like a coded key if possible as I'm not the biggest fan of codes and the dabber ones are a pita
Thanks tom
Thanks tom
Thanks tom
have suggested it before ... hella 12v DIN outlet socket in the dash ... just looks like a conventional power outlet ... connect in series with the dead man's solenoid valve/switch .... and have a plug with a simple link in it ... no plug - no workBall Valve on the suction side of the pump.... Will f**k the Pump if the engine is left running by wankers but would save it being stolen! Simple and highly effective.
Other option for your Case would be a ball valve somewhere on the hydraulic Drive train to Immobilise it. All thieves are electrical experts.... hydraulics not so much
Don't forgetA strategically placed ball valve is the way to go...... but not on the pump inlet! That's just crazywhat if you forget yourself some morning, start the machine up to warm up and walk off for 15 mins, pump f***ed 5k gone just like that!
between P & a FTT line, tee-ed off - with a tap, or a 3x1 diverter valve ... probably easiest, at the far end of the line from the servo pump, before the servo valve block ..... kill virtually everything .. zero servo pressure availableA strategically placed ball valve is the way to go...... but not on the pump inlet! That's just crazywhat if you forget yourself some morning, start the machine up to warm up and walk off for 15 mins, pump f***ed 5k gone just like that!
On a track machine a ball valve between P and T on the servo lines going to the track paddles..... job done.
On a duck, between P and T on the drive petal I'd guess, or some other function.
have suggested it before ... hella 12v DIN outlet socket in the dash ... just looks like a conventional power outlet ... connect in series with the dead man's solenoid valve/switch .... and have a plug with a simple link in it ... no plug - no work... would take some finding
As ever just shows the immoboliser people dont talk to the machine people to know exactly who the product worksI had an issue with a dangle-key-fob immobiliser jobby on a machine. It came with 2 sets of keys/fobs, both of which worked fine with one set ‘kept safe’ and the others used all the time.
I misplaced the set I used after a couple of years, and the stored set subsequently no longer worked (the immobiliser wouldn’t recognise the fob). Long and short of it was the immobiliser had to be entirely removed and a new one installed as there was no way of recoding it to the existing or a new fob without a working fob...
Turns out that recoding these fobs involved turning the ignition on/off a certain number of times with the existing and new fobs present - any non-present fobs would be deleted from the immobiliser’s memory. To depressurise the hydraulics on my machine to connect/disconnect hydraulics involved turning the ignition on/off whilst operating spools (you can see where this is going!!!). I’d unknowingly instructed the system to forget my spare keys, which was an expensive and frustrating mistake...
got a system like that on my Hodna Goldwing .... haven't used the spare -- everI had an issue with a dangle-key-fob immobiliser jobby on a machine. It came with 2 sets of keys/fobs, both of which worked fine with one set ‘kept safe’ and the others used all the time.
well that's good to hearAs far as I’m aware, with the sterling fobs the RF Id tag doesn’t have a battery and the loop induces a very small current enough to transmit a code? So long term storage shouldn’t be an issue. Spares ain’t dear at £16 per fob either. But I’m not affiliated with the company in anyway so can’t say that is exactly how they work but I’ve fitted them on quite a lot of machines and bar the issues mentioned above with steel enclosures I’ve never had an issue.
