well the recuperation/
honeymoon is over .. ..... ..
they say..
"trouble comes in threes" ...
well after the car last week and the boiler issues earlier this week ...
Vicki on the phone early Thursday ... with water dripping from Clara's bedroom ceiling !!!
Had me BIL coming to give me a hand sorting some errant slates, after all the winds we've had
... well he was gonna sort 'em and I was gonna get him up there in the basket
... Vicki got priority, so shortly after he arrived we shot down the village for a look see .... cold water header/expansion tank in the ridge of the loft leaking - properly ... concluded a split somewhere, so set to getting the bugger out ... which we eventually managed after some careful persuasion
having wrestled it past all the pipework and wriggled it out of its resting place, 'twas pretty evident 'twere fooked
... but only slightly
dashed into town, with the offending item, hoping to find a replacement that'd fit the space available or better still a like for like replacement .... reg,s changed recently apparently and .... no chance ... all very different now
managed to find a supplier who could offer very similar physical dims, but a very different tank ...but at the earliest, today or more likely Monday/Tuesday - bugger !!
the problem with the original was a couple of small cracks that'd developed around the base of some internal ribbing and the supplier, who I've dealt with for many years, suggested a temp fix with some CT1 adhesive/filler, that works and can even be applied, under water - -
like sticking tiles to a swimming pool wall whilst said pool is full
so new tank ordered .... tube of CT1 in hand, me and the BIL set off home to effect a temporary repair on said tank, so' we could at least get the heating and hot water functional for a few more days, on the old unit, whilst the new one made its way to Druid central and we could be impressed at the performance of this CT1 stuff
internal ribs suitably plastered and some flexible cover patches bonded to the under sides .... welding curtain seemed a fair option
we returned to Vickis loft to re-instate the bloody thing ...... went in a damned sight easier than it came out ... we had the drop on it .. refilled and all was nice and dry
observed it for a good hour and were happy ..... way too late for the originally planned slating job, so a.n.other date was set for that and Gareth went home after a cuppa and some of Pam's sponge cake.
22:00 last night - me phone rings - Vicki ... "
there's a bit of a drip" !!
****, **** and double ****
." I'll be down first thing ... stick a bucket under it and turn the main off babe "
the pic above is one I took this morning after extricating said tank ... AGAIN !! after taking Clara to nursery and returning home with the damned thing ... water had some how managed to find a way to track through the sealant inside on the web/tank wall interface, through the crack and then worm it's way out through the sealant holding the patch on ..... well unhappy !! (
the missing bit is where I'd rubbed it off)
cleaned everything off ... meticulously clean .... scoured it all with course glass paper (
sand paper to them that don't know better - sand paper doesn't exist) and remade the seal / patch repair ....
back to Vicki's .... re-installed the repaired tank
in situ, left it dry/drying, all in time to collect Clara at 12
as per , as the sun was out here, for a miraculous change .. she wanted an hour in the park on the swings/slide/etc. ........ half twelve I get a call to say the new tank had been delivered
"I'll be in shortly - just installed the old one again for the second time - long story - see you in twenty min.s Peter "
He was amazed the CT1'd let us down !!
"C'est la vie "
Shot into town with Clara and picked it up ... very nice .. but very different
going to need a lot of plumbing re-juggling to persuade this into the original location and after examining it in the loft, as a comparator ... concluded 'twas a job for a.n.other day, suitably armed, with a bucketful of plumbing fittings, extra pipe and more time than I had available today .....
so filled the repaired tank, checked it over yet again, turned the main off in case, strategically placed a few buckets and burgered off for some lunch, as Clara was now H U N G R Y
Spoke with Vicki at tea time and discussed tactics/procedure, for leaving it un-attended over the week end, if she went out anywhere - i.e. turn the bloody main off, in case, but ......... was all still dry and dandy when we spoke, so hopefully if there're no issues in 24 hrs, there won't be any and I get some breathing space, to get yon new one installed
not heard anything
bad , this evening, so fingers crossed
So that's three
'problems' ... in double quick time ...... they/I/we have had our quota for a while ... hopefully
